Wiper Blades - 24" versus 20" - Go For The 24"!!!
#31
Originally Posted by mrxlh
Jeff, I must say, excellent cheap mod. I put a set on today, wow what a difference.
#32
Thanks again Jeff, even though I had just bought new 20" winter blades a few weeks ago I bit the bullet and shelled out for another set of winter blades in 24". I did notice that the extra length was making a slight streak but that's probably just where the Rain-X hadn't been rubbed by the 20" blades. I'll retreat the windshield tomorrow and see how it goes. We have not had much adverse weather but there was a little fog the other night and the extra clean area was nice. To me it's more noticable on the passenger side giving you more visability over the right fender when looking for oncoming traffic at an intersection. Now I have to see if the 20" blades will fit the Crown Vic of Freestyle, or find someone to give them to....
#33
Dang, something ELSE I need to do !!!!
One thing mentioned was rain-x ....
for those of you that's not tried it the rain-x you add to the windshield washer bottle makes your blades last longer in two ways
1) you don't need to use your blades as much (have been in drving rain @ 60 mph with no wipers and could see better than with wipers on)
2) makes the glass "smoother" so less drag !
it's a win - win !
#34
it's a win - win !
#36
#37
#38
The way that I heard to use the two is that you use the bottle on the windshield first, as they recommend, and then add the wiper solution. The washer fluid should make the window treatment last longer. I've got to say it works pretty well, though I haven't got it up to snuff now. I do remember getting splashed by a big rig, last year,with slush and water so hard that I thought I was going to crash and then realized I could actually see. It does make a difference.
#41
#44
#45
My arm loops around the blade like a hook, and there is a pin that goes through the "eye" of this loop through a shaft in the blade body. There is a little lever that moves, but nothing happens when you push it...maybe the blade is just stuck as it is three years old.
My new Bosch blade has the "eye hole" without a pin. I assumed the pin from my old blade was to be reused.
