1978 351W Timing Marks?
Old Dec 20, 2006 | 12:12 PM
grover2044's Avatar
grover2044
Hey all, I am new to the site, and have been doing alot of looking around. I have a 1978 E-150 with a 351W in it, and for the life of me I can't seem to find the timing marks. Does this engine have timing marks? If so can you please point me in the right direction...Thanks all
Old Dec 20, 2006 | 12:50 PM
subford's Avatar
subford
It depends on your ignition system, if you have a Duraspark III then no it does not.
Old Dec 20, 2006 | 12:54 PM
pfogle's Avatar
pfogle
Does it still have the emissions sticker? If it does what does it say in the "computer" or "engine controls" You're looking for DURASPARK, and it will be either 1, 2, or 3 (EEC-III). If it's EEC-III (duraspark 3) then the timing is controlled solely by the computer. If it's Duraspark 2 (indicated on the bottom of the emissions sticker), then it's a vacuum controlled system. Look at the crank pulley from the top, and see if you have a point. If so you'll need to crawl under the van with a large breaker bar with a socket to fit the bolt in the crank, and a wire brush or a brush head in a drill. Clean up the harmonic balancer and get as much of the dirt and rust off as you can. If you can then see the mark paint the area black. Find out what the base timing should be and mark that spot with a white stripe. Oh and Welcome to FTE!
Old Dec 23, 2006 | 08:53 AM
beaners1's Avatar
beaners1
I had the same problem with my 80, felt kinda dumb when I finally found the marks on the harmonic balancer. It took alot of brake cleaner and rags to get all the dirt out of them. The marks are not very big but they should be there.
Old Dec 26, 2006 | 05:25 PM
Davetopay's Avatar
Davetopay
HAHAHA....he said 1978.....that is a 2bbl 351. No computers there! It took for ever to find the marks on mine as well, they were full of nearly 30 years of crud and goo.
Old Dec 26, 2006 | 05:36 PM
subford's Avatar
subford
Why do you think it does not have a computer?
Old Dec 27, 2006 | 06:49 AM
Davetopay's Avatar
Davetopay
Ummm... because there are none on that truck. I have the same year/model. I also had a 79, which was not computer controlled. The stock carb is a 2bbl holley, the ignition is electronic, but advance is controlled by weights and vacuum. There is NO powertrain computer in a 78 E150. That's all there is to it.
Old Dec 27, 2006 | 07:47 AM
subford's Avatar
subford
You may be right as Autozone says 1980 but I think I have heard of some from California as early as 78 or 79. They were sold in California and had a Computer and did not have the Ignition you speak of. Also a few were sold in other states also.
Autozone also says that the DuraSpark II was from 1979-1988 but my 1977 F250 has a DuraSpark II, so there you go.
I do not know what was sold in Canada.
But yes I would say about all sold in VA (your state) had the system you talk about.
The Computer was under the driver’s seat and there was not any primary wires going to the distributor and no vacuum advance on them either. There was also a pick-up at the vibration damper.
Old Dec 27, 2006 | 02:11 PM
pfogle's Avatar
pfogle
If it's cali-emissions then yes it has a computer. That started in late '78 early '79. Also just because your vehicles didn't have them does not mean his does not. Also DO NOT trust autozone... They can't even tell you what transmission comes in most older cars. They have no listing for a 351w and a C4 in a '79 LTD. Does this mean it wasn't a factory car? NO, it just means that whoever setup AZ's database is an idiot.
Old Dec 27, 2006 | 07:06 PM
Davetopay's Avatar
Davetopay
Point well taken! I hadn't considered the "Cali-emissions" angle. Sorry if I came off like an ***. But hey, you learn something new every day!
Old Jun 29, 2011 | 08:56 PM
ckline7035's Avatar
ckline7035
I'm in the process of cleaning the gunk from the balancer, and it seems that the one on my 78 351w is not stamped very well. I've used brake cleaner, mavel oil, wd40, and a lot of rags and scotchbrite pads, and can barely make out one or 2 numbers...what I need to know is what order they are on the balancer. My buddy that is supposed to be a "ford Man" couldn't find them, or even say if they were there. He also was the one that pulled my distributor, because it had to be 2 teeth off, then It wouldn't run right afterwords. I'm a Chevy man and got under there and scrubbed it off, and believe me , they are there. Mine just are almost nonreadable. The pointer line is the edge of the bracket at about 10 to 11 o'clock on the front of the block, as you face the engine.
Old Jun 30, 2011 | 04:39 AM
subford's Avatar
subford
They should look like this:
eric8
Feb 28, 2017 08:35 PM
BGF100
Oct 15, 2016 09:58 AM
Nevada Dan
20
Jul 31, 2011 10:59 PM
78Ranger400
Nov 5, 2010 06:22 PM
taylen
1978 - 1996 Big Bronco
Aug 25, 2005 06:56 PM
