Brakes went south
Brakes went south
Coming back from Jim`s for breakfast this morning my trucks brake pedal would start shuddering when applied. Even when sitting still in driveway it does the same thing. Redid the brakes not too long ago.I just checked and it`s not throwing any codes,fluid is fine.Need to go to Tahoe tonite so pls. chime in with any ideas
Thanks
Hanklin
__________________
Thanks
Hanklin
__________________
By shuddering do you mean the pedal bounces slightly when pressure is applied?
Could be a hydro boost issue, hows the PS pump?
Brake Booster
With the transmission in NEUTRAL and the engine stopped, apply the brakes several times to exhaust the vacuum in the vacuum boost system or the pressure in the Hydro-Boost system.
Hold the brake pedal in the applied position.
Start the engine.
If the power brake system is functioning properly, the brake pedal can be felt to move downward after the engine starts.
With a vacuum type power brake booster, if engine vacuum is available to the power brake booster and no power assist is felt, replace the power brake booster and retest the system.
If power steering pump pressure is available to the Hydro-Boost power brake booster and no power assist is felt, replace the Hydro-Boost power brake booster and retest the system.
If power steering pump pressure is not available at the Hydro-Boost power brake booster, check the power steering pump pressure and flow.
Accumulator, Hydro-Boost Only
Start and run the engine.
Stop the engine.
Apply the brakes. The accumulator in the Hydro-Boost power brake booster should retain enough pressure for at least two power assisted brake operations. If no power assist is felt, replace the Hydro-Boost power brake booster and retest the system.
Brake Booster
Start the engine.
Stop the engine.
Exactly,Ialso a like a bump,bump bump noise,I`ll go try what you said and post again shortly
Hanklin
Hanklin
Ahh the anti-lock is more like a real strong vibration in the pedal - and you can HEAR it too....
Good luck changing out that pump - let us know how it goes - I have a feeling I might be doing mine before long.....
