V10 Exhaust Questions. Muffler and Manifolds.
So here are a few more questions. My truck is under an extended warranty. My dealer said that they were unsure if I could put pipes on without voiding the factory warranty. I checked through all the warranty stuff and my warranty only covers from the cat. forward. All the work I want to do is from the cat back. So, I should be OK, right? It is not like a FM 40 is really doing anything to anything covered by warranty except maybe letting the truck breathe a little better. Second, what about single vs. dual. I had duals on my last truck, but never really saw a need for them. All I am concerned about is sound, not the .000001 MPG better I can get. I know duals lower back pressure which can be debated as good or bad. I just don't see paying the extra $110+ for duals verse a FM 40 with a single 4" tips 45 degrees out the back. I think it would look just as nice as duals. Are there any sound advantages to duals? I would think you would be able to hear it better in the cab with the windows rolled down with duals?!?!?
the dual set up will give you a 0% gain in any thing . as to the muffler stay with a slightly bigger one "50 eries" in mass . esp since i know what my step bother goes though up there on the cape with his 350/350 powered 100 point restored 67 nova and he has the stock type exhaust on it.
the v10 is a hard engine to tone tune the exhaust on. some are louder inside the cab then others are outside so be prepaired to change it if it's bad inside.
You should be fine regarding the extended warranty. They like to use the "scare" tactic because they themselves do not understand the warranty.
Regarding the dual exhaust issue. Do it if you want to spend the extra $110+...but...
As already mentioned...no advantage going dual from the muffler back that a single 3" or 3.5" exhaust would do. As for the FM40 or other muffler type...that is all a gamble at best. I personally do not care for the extra noise factor...and heck I even installed a FM70 3" in / 3" out single exhaust on my 1976 F150 390FE. So that shows...I like the throaty sound...just not the noise. We all have our own tastes...and just my .02 here.
Good luck with your choice...
biz
biz
It's really not as hard as it would seem. It is a snug fit...but there is still a little room to play with. But yeah if you are really serious about the duals...I'd go for it...they look great on my truck...and I don't mess around when it comes to my truck...I like things to be amazing with my truck! Good luck with whatever you decide.
I checked my manifold bolts today when I finally had some time while it was still light and all 9 of the bolts that are in there look good lol! It seems like they have been replaced at some point, but the one furthest to the left when looking in the left wheel well just isn't there. Not that it broke off or anything, it is just not there. I can put a pen tip in it without any problem. I am thinking someone just didn't put it in or something like that. I am taking it is for service this coming week and that will be addressed. This has to be where the ticking is coming from. I heard it on the right side. Would this cause ticking only when in drive?
#30
640 CI Aluminum FORD
Aftermarket Products
09-27-2011 02:03 AM
