Winter projects?
Old 11-26-2009, 08:58 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
Winter projects?
What are you guys working on in the garage this winter?...................We are building a new 2.3 Ford 4 for my buddy's 83 Ranger 4x4................Lots of nice aftermarket parts for it, a lot more than were avail. for my 2.8 v6. Since its not a daily driver, we have time to do it right!...............What kind of "garage money holes" are you guys working on?
Old 11-27-2009, 08:19 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
I have two projects to do this winter. The first is to bring in my 73 HiBoy chassis and remove 16" from the middle of the frame, weld it back together and install my 53 FORD panel onto the shortened frame. Then I have to paint the top of the hull on my 16' Sidewinder ski boat with the new red metal flake, and install the new 200hp in-line 6 into it. I'd like to have both ready for a GTG on the Columbia River this summer.........
Bikini's and water skiing, is there anything better!
Old 11-27-2009, 05:20 PM
Medicmike63's Avatar
Medicmike63
Medicmike63 is offline
Doing the body work a bit at a time on my '79 to get it ready for paint in the spring.
Old 11-27-2009, 07:53 PM
customcab66's Avatar
customcab66
customcab66 is offline
in the middle of my winter project trying to get the exhauste fixed on the old ford got the headers done today got to finish the rest of it
Old 11-28-2009, 09:16 AM
bertha66's Avatar
bertha66
bertha66 is offline
I'm working on the rubber around the windows of my 66. The antirattle kits are a real pain.
Old 11-28-2009, 09:21 PM
Chucky Babe's Avatar
Chucky Babe
Chucky Babe is offline
starting on the 71
Old 11-28-2009, 09:24 PM
Chucky Babe
well im going to start restoring my 71 f-100 and to start it off i just put a HOLLEY 650 Double Pumper on it
and starting the sas in my B2 to a 9in rear and 44 front
Old 11-28-2009, 09:36 PM
Old93junk's Avatar
Old93junk
My B2 project fell thru when my wife took ill, I just wish I could find a decent 84-88 B2 to restore with no major mods and drive................My 15 yr old Daughter is taking over my 84 Ranger 4X4 V6 a little bit at a time.........She hates cars, and only wants a 4x4 truck.
Old 11-29-2009, 01:05 AM
892504x4's Avatar
892504x4
892504x4 is offline
I wish I had some place to work on my wood drift boat. (no garage or shop)
Old 11-29-2009, 01:28 PM
customcab66
getting my tail wooped by my winter project my headers will not seat up on the passenger bank of the motor
Old 11-29-2009, 01:39 PM
Old93junk's Avatar
Old93junk
You may have to pull the bolt holes a little with a die grinder, works wonders.
Old 11-29-2009, 02:06 PM
customcab66
not sure what that is
Old 11-29-2009, 02:14 PM
Old93junk's Avatar
Old93junk
Air powered straight grinder with a carbide burr tip, does about 22,000rpms. Will elongate any bolt hole to make up for error in bolt pattern.
Old 11-29-2009, 10:12 PM
Old93junk's Avatar
Old93junk
Are you building one or restoring one?..........1 guy I knew just rented a big storage unit over the winter to work on his boat and truck. It had power and he brought in lights, worked very well.
Old 11-29-2009, 11:39 PM
customcab66
got the tail pipes done and sealed up now just have to get the passenger side header to seat up they just won't seal up not sure if there may be something wrong with the header surfaces to the head will probably take it back apart and look at the gaskets that i just put in and look at the problem hope nothing that i can't handle
Quick Reply: Winter projects?
