any tricks to replacing the water pump ?
I do have a leak at the weep hole. A good friend is a mechanic - not a diesel mechanic but has a full shop. He looked up the online technical manual for it and it looks pretty straight forward.
Any special things to watch for ? Any special tricks ?
How much anitfreeze / water does the cooling system hold ??
Granted yours is an '01 but you still might find this article helpful:
CLICK HERE
Your coolant system holds eight gallons.
CLICK HERE
Roughly 8 gallons
Might want to look into the Red ELC Coolant no service for 300,000 miles (Rotella ELC, Final Charge ELC (Walmart Label))
And
Maybe a one piece replacement and eliminate the lower gasket
Its pretty straight forward after you get the <>?: fan off. Its reverse thread and the nut is larger than most of the Rent-To-Use stores have
And
CLICK HERE
CLICK HERE
Maybe this article has the correct number but I'm sure I saw a correction to one of these write ups.
I'm not hacking your help, I'm just trying to make sure.
I knew I wasn't crazy...
Here is the thread https://www.ford-trucks.com/forums/5...ght=water+pump post number 7 says the torque is only 17 ft lbs.
This isn't the thread I remember, but the number sounds right.
Edit: This is the one I was thinking of...https://www.ford-trucks.com/forums/5...ght=water+pump
Originally Posted by Orezona
Wasn't there a correction to the torque pump bolts? I know I've seen it a few times from somebody that learned the hard way.
Thanks for catching that.
Turxx
19
11-25-2013 06:57 PM
familyman
10-27-1999 06:05 AM
