I've got 3 bad glow plugs in my '93 7.3, I've heard I shouldn't replace part of them, that they will burn out again soon unless I replace them all together. If thats the case about how long could I expect them to last if I replaced just 3?
Thanks
Not too long as they was running longer while the other 3 was not workling. It would just be a good idea with the cold weather upon us to just do all at once rather than doing it peacemeal and having to do it several times. Also it could mess up the GP controler/relay.
I agree. Also make sure you get motorcraft/beru GPs. Use anti sieze and watch the torque. Make sure you blow the dirt away from the holes before you pull them out.
They may not last too long if you just replace the 3 bad ones, but the other 5 will last longer if you replace the 3 burned ones. If the budget is really tight, go pick up some used ones from a junkyard to replace the burned ones until you can afford to replace all 8....
I replaced just one bad one earlier this year, against my better judgement of replacing them all....had hard starting when the cooler weather arrived...just replaced all eight, starts with no problems at all now.
Well, I ended up having 6 bad plugs, I guess some more went out since I tested them last week, so I replaced all 8 with motorcrafts. But, after I replaced them, I checked them with a volt meter. I am only getting 9.8v at each plug. I'm only getting 10.5 at the relay. I've got 12.5 on the battery side of relay. I have the controller bypassed with a manual push button switch. The relay is clicking over. Could it be clicking over, but just not carrying enough current? Or are the plugs only supposed to get 9.8 volts?
With the heavy current draw, they are likely pulling the system down to 9.8 when heated up. E= IR Voltage drop= Current x resistance. with a battery voltage of 12.5 as the current is flowing through the glow plugs the resistance increases, leading to more voltage drop or loss as the system heats up. The plugs are wired up in parrallel, so when one or two fail, more current is flowing throught the rest, thats why they burn out quick when they start to go.
So what should the voltage be at leaving the relay? And at each glow plug shouldn't it be within a couple tenths of a volt difference from the measurement at the relay ?, unless my wires are bad and have a big voltage drop?
Thanks
My advise to you is to change all the plugs at once and make sure you only use BERU plugs that say "Made in Germany" right on the body of the plug.
Seb......
Just out of curiousity, is there more than one Beru plug that will fit a 93 7.3L? The ones I bought at the local International dealer two weeks ago didn't operate the same as the Autolites I took out. The wait-to-start light took way longer to turn off, and the controller wasn't cycling evenly like it used to. Thought I was going to burn up 160cad worth of plugs. Of course I checked them with a hot light, and they were fine. Different voltage maybe? Controller going bad? I'm puzzled.
thats because autolites are crap. you are lucky you got them out without pulling the heads. the motocraft-beru plugs take longer to heat up, so they will last longer. i got 16 years out of the set in my 88.
If you ever get a chance to cut a burnt out Autolite and a Beru plug tip apart you will see the difference between the two designs. The Autolites come on fast and glow fiercely but burn out faster and swell the tip so you can't get them out of the hole.
The Beru Plugs take longer to glow with a more steady glow as you have noticed in your controller cycling.
There is a huge difference in the design of these plugs and that is what makes the Beru work longterm while the Autolites fail quickly and on top of all things swell up.
