429 truck engine Forged crank or not.
If it is indeed a 429 and not a 370 it will be a forged crank. I think there was a post awhile back that had pic's of a forged crank that showed how to tell the difference. You will have to at least pull the pan to find out what it is. They do require some machine work to use them in other applications than a truck engine.
Im looking at building an engine for a Pro stock pulling truck our rules are 480 cubic inch limit factory cast iron heads and a 850 cfm max. carb
And i haven't found a Forged steel crank in stock stroke and i know poeple have machined the snout down on these cranks and then offset ground them for a application like this.
I asked the guy and he told me it was a 429 and not a 370 but somewere i heard that not all of the 429 truck engines had steel cranks so i wasn't sure on that one.
What would be a good price if it had the steel crank?
Thanks.
P.S. I haven't had any words missing on my posts that i now of
Thanks.
That's what I have in my pulling motor. I got one that had a spun rod bearing and had it offset ground and finished with a 2.200 rod journal to use a long rod. It's hard to say on the price,I've seen some on the net for $500 without any of the machine work. They are also expensive to balance. Mine took three pieces of mallory at $75 each plus the cost of balancing.
Jon I think you are talking about Terry's motor and he offset ground a cast 429 crank to 3.85 stroke it wasn't even a steel crank. You would be amazed at what those cast cranks will take so I wouldn't give up on a 460 stock crank it's a stout piece.
As to the 370 vs 429, one thing to look at is the block casting number, if it has the D9TE-BB casting number it should be a 370, the 429 should have the D9TE-AB casting number on it. Thats not 100% as we found out earlier but it's probably 99% anyway.
hello tomas you are building a truck for red river?
honestly with those rules i wouldnt worry about a stock cast crank
the truck underpressuer i think you have seen him pull in north dakota right?
well he uses a stock crank that is just a idea on what a crank can handal i have seen the motor hit well over 8000 rpms i ran a stock crank for over 3yrs with those same rules in heartland pullers and never had a issue with one but if you just want to get a steel crank check into a scatt or? sometimes buy the time you buy a stock steel one and get it turned and the balincing done you might not save any cash just a thought
Can I hijack your 16 year old thread?
And ask about a 70 car 429 crankshaft
From what I read above a 70 T-Bird 429 crankshaft is cast?
Is it internal balance? Worked on those old piles at the dealer but do not know all the particulars
If you were to twin turbo a 70 429 what all would you do?
Pistons? Forged stroker kit? Heads? advice please
There are some differences in the rods, which are better than they look; with some having straight cut bolt seats and some having spot faced. This is a moot point since the stock rods seldom break in that area irregardless of the machining differences. If they fail it is usually in the beam about 1 inch above the big end. There are some later rods that came in truck applications which are heavier. The balance pad at the end is on the side of the small end on the regular rods and on the top on the heavier version.
