What would be necessary?
Old Dec 2, 2006 | 11:38 PM
Tony238's Avatar
Tony238
What would be necessary to put a mid 80's 460 with a ZF 5 speed into a 76 F100. The 76 right now has a 360 with a three speed transmission. Thanks.
Old Dec 5, 2006 | 05:05 PM
Tony238's Avatar
Tony238
Should I repost this in the 73-79 forum?
Old Dec 5, 2006 | 06:01 PM
RTM's Avatar
RTM
I can't recall what year ford started to put the 460 in a 4x4 truck. Even if they did you may have to change out the frame pearches but this is a complete guess on my part.
Of course you will need to fab up some sort of HYD set up for the clutch which I will have to do some time in the hear furture for my 78 ZF 460 bronco project.
In my case I could have used the stock tranny cross member mounts to bolt in the ZF but i choose to make my cross member fit the ZF tranny by cutting and welding to try and get a cleaner look. The stock mount on my bronco would have been hanging off the back of the cross member plus I didn't have that piece at the time of install or moc up of the ZF in the chassis.
Not sure if I helped you or not. I would post or atleast search the 73/79 forum and find out if the 76 truck ever came with a 460 and then look into the frame pearches to see if they are different.
IMO what ever it takes I would make it fit. I've made my own mounts for 460 swaps into 78/79 4x4 trucks before.
If you do decide to make your own mounts I would pick up on the center line of the crank and the output shaft and install the 460/ZF to the same measurements. This will help keep the drive line angles close to what they are now.
Old Dec 5, 2006 | 08:47 PM
monsterbaby's Avatar
monsterbaby
I wouldn't bother with the frame perches several companies make swap motor mounts, as well as one member on here who makes solid ones.
As to the ones that aren't solid I feel these are about the best.
http://performanceunlimited.com/cust...ginemount.html
I have also seen ones built by making an adapter plate for 400 motor mounts to mount to 460 blocks.
Old Dec 6, 2006 | 04:11 AM
RTM's Avatar
RTM
Those mounts are only for an engine swap when going from a 351M/400 motor to a 460 not an FE to 460 unless I missed something on that page.
dougx
Large Truck
May 9, 2020 09:53 PM
Psycho Cripple7
Mar 6, 2017 02:13 AM
n2o
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Dec 17, 2016 06:28 AM
TX76F250
Feb 1, 2013 03:48 PM
76Forder
Jul 22, 2005 01:56 AM
