1960 F-100, starting problem
Old 02-28-2002, 06:33 PM
VonDann
VonDann is offline
VonDann is starting off with a positive reputation.
Post 1960 F-100, starting problem
The 60 hasn't been started for several months.
It cranked 3 times, battery low. Charged a while at 10 amps,tried again but left charge on during crank. Got only dash lights,wouldn't crank.Then no dash lights either. Dash lights eventually came up,still not crank .
Charged at 2amps all night. Battery had 13 volts showing,tried again with same results. Dash lights but no crank,then no dash lights.
No headlights either.
Any ideas?!
Old 02-28-2002, 06:42 PM
truckzilla
truckzilla is offline
truckzilla is starting off with a positive reputation.
Charge your battery over nite and take it down to the auto parts store and have them check it. My first guess is its shot
Old 02-28-2002, 07:26 PM
VonDann
VonDann is offline
Thanks,I'll try that or maybe one I know to be good and see if there is different result.
Old 03-01-2002, 12:42 AM
mtflat
mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
[updated:LAST EDITED ON 01-Mar-02 AT 01:45 AM (EST)]Make sure your battery, ground and solenoid connections are clean and free of corrosion. If they're not, they'll act just like that.
Other things to check are the wiring and ignition switch.
Old 03-01-2002, 01:23 PM
texasbob
texasbob is offline
texasbob is starting off with a positive reputation.
Once you get a battery you know is good, and all connections arae clean and tight if it still won't show lights or crank it may be the starter. I had a starter ground out on me and it would take a freshly charged battery down in one crank. Most likely it's just the battery.
Bob
Old 03-04-2002, 10:55 PM
truckzilla
So!! Was it the battery or did you find somethin' else??
Old 03-11-2002, 10:14 AM
hirschi
hirschi is offline
hirschi is starting off with a positive reputation.
Old 03-11-2002, 01:04 PM
VonDann
VonDann is offline
I put another battery from the car and it fired right up !
Noticed the neg cable was loose at removal , next day put old one back in but sure it was tight.
Fired up like before! Duh!!
Thanks for the concern and the help !!
I'm sure I'll need real help sometime !!!!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
