Bad Oil leak....is truck worth it?
I'm looking at purchasing an 89 F150 4x4. The body is in GREAT condition, the truck runs good with 169K on it. The only problem is it leaks ALOT of oil. I test drove it about 20 miles, and it leaked almost a quart. With a quick look, it looks like it's leaking from the valve cover and the front seal. I tried to tighten the oil pan, but they all seemed snug. Obviously the valve cover leak will be easy, but I'm concerned on how big of a job the front seal is to replace. It's a 5.0L engine, and I'm wondering if I can do this myself. About the biggest job I've done myself is replacing the rear seal on my 87 inline 6 F150. My dad doesn't think the truck is worth it, but I think if the job is something I can do myself, the truck is a steal at $500. So my questions are:
Is this something I can do myself?
What are the steps to replacing the front seal? Does the motor need to be pulled?
Is the truck worth it, or should I just look for another?
Also the clutch slave might need to be replaced, I've never done this either, but this isn't that spendy or hard of a job is it?
Thanks for any info you can give.
It's worth 500 bucks just to have a Ford to haul your snow shovel in. I'd look the rest over real good (suspension, u-joints, tires, etc) before you make a decision. You don't want the old man saying "I told you so". Hope you have a garage to work in, hear you folks are in for some wild weather.
Good Luck
Good Luck
For $500 I'd say go for it. At worst you can always tell your dad it's a learning experience and part it out. When I bought my truck it had a similar leak which I figured to be from the front seal/timing cover. It turned out the cause was rust pinholes in the oil pan. It was hard to see because the engine was a ball of grease.
If it's just the front seal, it's relatively easy to replace and can be done in the vehicle. You can rent or get loaner tools at your local auto parts store. Take off the belt and pulley, break the harmonic balancer bolt loose and remove, use a balancer puller to remove the HB, pull the old seal and install the new one. If you did the rear seal on your other vehicle you know the importance of driving the seal in evenly. Reinstall the balancer using a balancer installation tool, put on the pulley and belt and you're done. Don't use the balancer bolt to press the balancer back on and don't hammer it on either. While the balancer is off, inspect the rubber holding the outer ring on for cracks and excessive protrusion and replace the balancer if necessary.
If you have to replace the oil pan in the vehicle, that job is more involved. You need to raise and support the engine. To gain enough clearance you will need to take off the upper intake. Then mark and pull the distributor and ioil pump drive rod. Next remove the oil pan and oil pump (you won't get the pan off otherwise). You may want to replace the oil pump and pickup at this time for insurance.
If you buy the truck you should get a Chilton's or Motor Manual for the truck. They will give you enough guidance to get the job done.
