MERCURY Letter Clips Part #'s
Perhaps there are a few of you out there with Old Part # Books. I need either a part # or substitute fastening method for the the M-E-R-C-U-R-Y Letters accross the Hood of my Canadian made '53 M100 Pick-up.
It's the fastening clips I'm trying to source. Any help figuring out how I can find a way to affix my newly re-chromed letters to the front of my truck would be appreciated. The holes are much larger than the actual pins on the back of the letters and much bigger than all the clips I've seen over the past few years of perusing the clip vendors at the local [Southern Ontario] swap meets.
Thanks
GW
Thanks
GW
on
Originally Posted by 51dueller
This is a little but I would think it would be cool to put one of these badges on a 53-56 Mercury truck.
on
Thanks
GW
Thanks
GW
There are the "round" ones & there are the "oval" ones.
Which do you have?
Also, Metal Clips & Rubber Gromets were used, so either are correct.
Hey Guys,
For the record, here's a complete breakdown of this assembly.
Letter "M" #CDBAAA-1606-A
"E" #CDBAAA-1606-B
"R" #CDBAAA-1606-C
"C" #CDBAAA-1606-D
"U" #CDBAAA-1606-E
"Y" #CDBAAA-1606-F
The letters are to be held on with a retainer #C04M-7021048 wich is backed with aself threading nut #355891-S. Alternately, they should be able to be held on with retainer cup washers #351601-S8A followed by lock washer #34940-S8. This info should hold true for all Mercury trucks 1953-1956 in all series of conventional and cab forward models. The only difference is in the Parcel Delivery Van in which the part number for the center letter "C" is CDBRAA-1606-A. Hope that helps eveybody.
Keep on MERCURY Truckin!
Scott Wilson
1953 Mercury M-350 Wrecker
Canadian Mercury Truck Registry -rep
MSN Mercury Pickups Forum - asst. moderator
"E" #CDBAAA-1606-B
"R" #CDBAAA-1606-C
"C" #CDBAAA-1606-D
"U" #CDBAAA-1606-E
"Y" #CDBAAA-1606-F
Scott Wilson
Hi Gerry,
Sorry, I don't know of a source for thes parts off hand. If you know of a Ford dealer that has been around from the fifties, give them a call. Also, though many of us don't think about it, many parts houses have cross reference books an can find alteranative pieces sometimes. Reproduction parts houses may also have some, just not in their catalog. Remember thay are usually hobbiests too, it doesn't hurt to ask.
carbs & chrome
WTB - Ford Trucks & other vehicles
05-09-2011 09:36 AM
trafficgoo
04-11-2011 07:21 PM
Herman R
03-17-2007 01:29 AM
