truck storage?
truck storage?
Ok I'm leaving next month to Iraq for a year. What can I do so my truck doesn't roit in my driveway? I have a friend that is goning to watch my house and start the truck up when he gets the mail. What can I do so she doesn't fall apart when I get back? Should I change the fuilds just to change them again when I get back? What fuilds do I change?
I was going to get some of these to help with mold:
SUM-HZD10000
Stay dry, with Zone Dry!
Before you tuck your car, camper, boat, or RV away for the season, protect the interior from mold, mildew, and corrosion with Summit Zone Dry. Each pouch absorbs its weight in moisture, and a colored indicator tab alerts you when a replacement is needed.
Thanks for any help.
Semper Fi
Warren
SUM-HZD10000
Semper Fi
Warren
Yeah, stay safe and your country thanks you, though they may not seem to pay what they ought to. The best thing you can do is have someone drive it at least 2x a month on more than an around the block trip. That ought to do it. I have mothballed a vehicle when I went to the Gulf war in 1990. Basically parked it in the basement garage and put it up on jackstands. Since that is not an option for you, put fresh oil in and have someone do as I suggested. Even starting periodically will help. As for the interior rot, I don't think that is that big of an issue as the brakes, seals etc rusting or dry rotting from lack of use, meaning taking it for a spin.
I agree with Tenn01PSD350 on getting someone to drive it around the block once or twice every few months.
All the seals & gaskets will thank you for that.
When ever I store a vehicle for an extended period I put a float charger on the batteries to keep them charged and ready to go. I got a cheapie at Harbor Freight for $7.49 that works great.
Last but most importantly, Thank You for your service!
Stay alert and alive and come back!
Austin
Austin
Semper Fi
Warren
Semper Fi
Warren
BUT ..... then I saw your sig; I also have a 99 4x4 and if I drove your rig with all those mods I'd have to start doing my own mods and then where would I be? I'd be safer in Iraq myself!!
CedricR.
I just bought a Solar powered Trickle charger off Ebay for $14. so now that its winter it keeps the battery charged when parked. then there are no cords running to your truck to trip on or forget to un-plug. It just sits in the dash and pluggin into the cig. lighter.
Take care and Cheers to your service to our Country.
Originally Posted by sweet03cobra
hey man, I'm having the same problem myself, i'm in iraq and tried to have the wife start it and it is dead. Which charger did you go with? I saw some on there from VW that plug into the OBDII port, I wonder if that would work good?
I would have someone from the rear detachment charge them up and then make sure it is started and driven periodically. How is your family support group? Where are you out of?
