Horsepower and Torque Numbers
As requested by Bowtiehatr:
'04 F250 2WD Crewcab SWB:
Exhaust and tuner--stock turbo-- 414hp/716tq
Exhaust and tuner--'03 turbo---- 444hp/728tq
All numbers with stock air intake system and toasted
headgaskets--soon to be fixed. Do you really need an
a/m airbox??? I don't think so!!!!!
i actually dynoed yesterday. best runs were 309hp and 602 lb ft.
here are the dyno charts.
best torque-
http://rides.webshots.com/photo/2477...91838520TObwTR
best HP-
http://rides.webshots.com/photo/2887...91838520FgKMYG
best torque-
best HP-
His truck is stock right now and the 3 trucks that he tuned for the dyno for are listed right here. 444, 414, and mine. My heads are questionable so I had him back mine down while Data logging the truck the night before we went to the Dyno. I was looking for 400 and Matt hit it pretty close I would say. Long walk back to Ohio from NC if we toasted my heads.
Mr Grandpa's '01 F-350 extd.cab long box dually 7.3L ZF6-speed dynoed about 293 hp, and 697 ft/lbs torque at the rear. Garret BB turbo, 4" exhaust all the way through, and BD's power programmer. He hit's max torque at about 2000 RPM, and it's table top flat until about 3000 RPM when it starts to taper. My '96 7.3L ZF 5-speed is about 225 hp and 425 ft/lbs at the rear. 50 hp chip, 3.5" DP, 4" exhaust, 5" tip, modified stock air box with K&N air filter.
Sorry...don't have any 6.0L numbers.
Originally Posted by BowTieHatr
kool, i still waitin for a freak out there. i know there has to be a 1000 horse 6.0 monster somewhere.
-bump-
comeone guys i dont care if its your tuners giving guesstimates or if your on the wheels. i am curious as to whats out there. come on matt, i know you have to have some hp numbers atleast.
Finally getting around to getting some of the heavy custom hardware together in one package; wintertime should give me time to finish.
Don't know if we can get to 1,000 horsepower off the bat. The engine setup I will be running *should* be reliable (as reliable as anything else at that output level) but as for the rest of the truck who knows. When you are talking 800+, everything behind the flywheel risks catastrophic and immediate failure, including the frame. I will say this- the fuel, air, and oil will be there. As for everything else, only time will tell.
sounds interesting. i know 1000 is almost unrealistic but i was in a dr pepper mood that day.... or any day lol. but you have to admit, it would be a awesome ride.
