97 Ranger Speedo/ odometer problems
Hello all, I have a 97 Ranger. The speedo quits working after about 5 miles into a trip. Works fine, bounces up and down then drops to Zero! The odometer quits turning as well. Any suggestions on a quick, cheap fix? Or is the best alternative to replace the whole thing? Any suggestions would be helpful, Thanks, Joe
Well I thought so.
Well I hoped to have fixed the problem, but on my 20 mile trip to work I got 3 mile from work and it bounced up and down again, then stayed all the way down. So now I'm back at square one. Any suggestions? I was also pondering on my way home, could it be that I need to change the rear end fluid? Flush the tranny? Track down the electrical end of it? This is what I have done so far, I changed the VSS on the trans, The speedometer cluster, and last but not least I changed the ABS speed sensor in the rear end. The truck has been good to me but I'm getting frustrated. It's a 2.3 4 banger, 4X2 5 speed, 113,000. Well any help would be great!!!! Thanks in advance, Joe
Plumbing2012
06-06-2013 07:06 PM
lildrummer420
10-11-2011 10:55 PM
alteran
05-16-2007 06:20 PM
TufEnuf
1997 - 2003 F150
06-23-2005 05:45 PM
