Front tank won't take fuel.
See my sig, my front tank won't take fuel at the gas station. Everything worked fine until Monday, I went to fuel up on the way to work - the rear tank was fine but my front tank will not take fuel - even slow it burps immediately. I tried again today and it still won't....This is wierd to happen all of the sudden. The front tank is one year old, the rear tank is a bout 1.5 months old. Like I say, everything was working perfect until this past Monday morning.
Anything common for this? I'm going to pull the hose off the tank after supper and see what I find.
To me it sounds like it is full. My pump has been performing poorly for the last few months on the front tank ... it quit last week and when I put gas in it, the gauge stayed on empty. I don't know if there is a crossflow problem on the 96 like we have in the 90-92 ... but you may have that problem. I will be replacing my pump tomorrow.
Manwith3fords
I have a 89 with dual tank they both are slow to fill. It has always been that way and I do not know why. Had the filler neck off both tanks, checked the vent tubes they are not crushed nor are they blocked. Must be one of those poor design features that Ford hasn"t corrected.
farmerboy
farmerboy
I just finised R&R 'ing the filler neck....Didn't see anything wrong and no blockages. I also put air through the EVAP line from the tanks - not plugged. I think what happened was the inner plastic tube was not pouring into the tank - I think it was fetched up on the tank neck and was not able to pour directly into the tank. I can't see anything else wrong so I'm heading to the gas station to see how I fair out....Will keep ya posted.
I have a situation similar to this but i figured out the porblem and now can not fix it. my inner tube has come off the top of the fuel neck by the door on the inside and i cannot figure a way to get the inner tube back on because it is up in too far. a factory retainer ring fell out with the tube, like it was crimped from the factory. any ideas? or do i have to resort to buying a new neck assembly?
No i couldn't get a hose clamp on it, i could not even get the hose started, the smaller hose fitting was way inside the larger hose fitting, (both metal at top). So i resorted to going to the junk yard and getting one that was still attached from factory. Next time though the diesel guys had alot of good ideas that they have in order to use the big pumps.
