missing-bad injector?
Old Nov 23, 2006 | 01:02 PM
weezle's Avatar
weezle
Red face missing-bad injector?
hello, I have 02 psd which I am very happy with and pull a travel trailer. I was able to pull this trailer up hill at 65 until a couple days ago. Now it wont pull it up the same hill over 50-55 M.P.H. The truck starts and runs great hot or cold. I changed the fuel filter and it was pretty dirty. I just had my wife this morning rev it up this morning while I stood near the exhaust. It appears to missing on one cylinder. Could this be an injector? or something simpler? Any information would be greatly appreciated
Old Nov 23, 2006 | 01:14 PM
Mikeysnapper's Avatar
Mikeysnapper
If it sounds that like it is missing it could be a bad injector and you will probably be able to find out using a cylinder contribution test from anyone with the right equiptment. I could be a leaking in the hoses or exhaust because you will be dumping the same amount of fuel but not using it right if this condition exist. all 6 hoses should be tight and clamps should be centered. any oil or grease at the hoses is where a leak once was but may be sealed partically but the acculimanation of oil it self. Under the truck ( hard to see) but look for soot on your down pipes toward the top of the turbo and there will be a Y collector. That is where mine was leaking and I had the same symptoms as U minus the missing but It was ruff and not much power under 2000 RPMs
Old Nov 23, 2006 | 01:18 PM
weezle's Avatar
weezle
Thanks for the info. I will have to do some investigating.
Old Nov 23, 2006 | 01:42 PM
Kwikkordead's Avatar
Kwikkordead
Don't be fooled by the normal Powerstroke exhaust flutter. To the uninitiated it can sound very much like an engine miss.
If you have a cylinder truly cutting out the engine will rock, just like when you pull a spark plug cable on a gas engine.
dfitch1
Jul 8, 2013 05:55 PM
Ratkat
Australia Chapter
Jan 27, 2013 07:37 PM
dougbrown
31
Apr 8, 2011 04:59 PM
sdunn9
Feb 18, 2011 05:17 PM
wstoughton
21
Sep 26, 2008 09:54 PM
