Sponsored by: Real Truck
Tire Chains??
Old Nov 25, 2006 | 12:36 PM
utahtom's Avatar
utahtom
Here is some info on the cables http://www.tirechain.com/CABLE_MOUNTING_INTRUCTIONS.HTM
One item of note is that from what I have seen in UT, WY, MT & ID if you have snow tires and 4 wheel drive, chains are not required. I always run studded snow tires (in the winter) and have never found myself to be in violation of any State laws in regard to mountain pass requirements. Also, there are a few A/T tires which supposedly meet the Severe Snow rating including BFG A/T but only in certain sizes.
Old Nov 25, 2006 | 03:04 PM
usroute66's Avatar
usroute66
Thanks Utah! Great website. I ordered me a set too!
Old Nov 25, 2006 | 03:30 PM
larryjj's Avatar
larryjj
Anyone know where the Tire cables can be purchased in tghe Surrey area of British Columbia ?
Old Nov 25, 2006 | 07:23 PM
Nitrous's Avatar
Nitrous
Try Canadian Tire. Also, there is a place, I think it's on 72nd ave between 132nd and KGH that specializes in chains and such.
Old Nov 25, 2006 | 07:35 PM
Bdox's Avatar
Bdox
If your tires are not M&S rated, carry chains no matter the vehicle. If they are not, you have a hard rubber compound and they will get very slick when cold, even if they have an aggressive tread.
In Nevada you are not likely to have a problem with authorities, but Calif is a different story.
If you have the right tires and plenty of snow experience you should be OK. But even good trucks with good tires can slide off the road.
The thing to remember is, if you can't go, it's discouraging. But if you can't stop, you're screwed.
Old Nov 26, 2006 | 10:04 PM
larryjj's Avatar
larryjj
Smile
Thank you Nitrous & Bdox.
I'll look into that place on 72 next time I am in the area.
It's true about starting and stopping on snow.
Especially snow with ice underneath.
Will have to put some weight in the back of my pick up to get better traction on the road.
Regards,
Larryjj
Old Nov 26, 2006 | 10:31 PM
arctic y block's Avatar
arctic y block
Remember the more weight the more distance it will take to stop. Just a thought
Old Nov 26, 2006 | 10:48 PM
larryjj's Avatar
larryjj
True,
But need the traction due to all the ice under the snow here from the cars with summer tires glassing the roads.
Old Nov 26, 2006 | 11:01 PM
yamaguy's Avatar
yamaguy
yea those are the most common type it seems like anymore.
Old Nov 26, 2006 | 11:20 PM
arctic y block
Keep her in low with a 3 inch exhaust and just blow em it the drifts on your way by HAAA
Old Nov 27, 2006 | 12:36 AM
NavyPowerstroker's Avatar
NavyPowerstroker
Last year here just east of San Diego there was some snow. So I took my 1 year old son out to see it and play. There were a few roads that only had a couple of inches and they wouldn't let anyone go through without chains. I thought it was pretty funny since there was only a couple of inches down. I told them I was from northern Idaho but they weren't letting anyone go through.
Old Nov 27, 2006 | 01:31 AM
arctic y block
Ya. Telling them you are from Alaska don't help either.
Old Nov 27, 2006 | 06:55 AM
  #28
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Moved ...enjoy
Old Nov 28, 2006 | 12:30 PM
  #29
larryjj's Avatar
larryjj
All these tire companies that are hyping people up about the fantastic traction they will get with their improved traction tires for ice and snow.
Well just look at all the accidents and the vehicles that are not going any where the last few days.
I am certain some of these vehicles are using those tires.
Regards,
Larryjj
Old Nov 28, 2006 | 02:18 PM
  #30
Stroker4Life's Avatar
Stroker4Life
Hey all you guys that drive in the deep snow with big tires, what brand and tread do you preffer? I have had the best luck with BFG mud terrains in the deep snow.
