canopy removal?
canopy removal?
Has anyone rigged up a pulley system in their garage or shop that would allow one person to remove the canopy off their truck? Is there something like this available to buy?
I have a Snug-Top canopy on my Super Duty and that thing is heavy. I'm not a small guy and it takes all I've got to move that damn thing when I need to take it off the truck.
If anyone has anything to share, I'd appreciate it.
Thanks,
Steve
Thanks,
Steve
here is one of many available options:
http://www.fiberlinkweb.com/specialty-products.html
good luck
good luck
Pulleys and rope from the local home box store will work. Pick whatever mechanical advantage you want.
https://www.ford-trucks.com/forums/4...ft-system.html
https://www.ford-trucks.com/forums/4...ell-hoist.html
> 8 single pulleys; 4 above the topper, 4 on the wall above the winch.
> 4 pieces of 1/4" line.
> Hooks to grab the topper.
> Wooden winch or windlass with crank to wind them up on made from two plywood disks with a short piece of 4x4 in between to wind the rope on. Use a crank handle of your choice, longer gives more leverage.
> 2x6 board with a 1/2" bolt thru it to mount the winch to wall studs.
> Varous screws and fasteners to mount the pulleys, winch board, and assemble the winch.
> Short piece of line to loop over the crank handle to keep the top in the UP position.
Don't stand under the topper while someone fiddles with the winch...
A neighbor up the street has a cradle he built as an attachment for his cherry picker. He basically built a V out of angle and has a couple 2x4s on top spread out a few feet. It's bolted to the head of the boom. He rolls it under the canopy and just lifts it off and lowers it down on a couple saw horses. Pretty slick.
I have built a couple using lines and pulleys. I made a harness for the top using webbing with three lift points.
On one, the whole assembly was mounted on a plywood sheet, which was hanging on a track made out of standard garage door hardware. This was because the top needed to be stored away from where it could be lifted. ( The tracks can go in any direction.)
