Arizona Chapter Join Chapter, Leader:
I Need Help!!!!!!
Old 11-21-2006, 10:21 PM
Melchiah's Avatar
Melchiah
Melchiah is offline
I Need Help!!!!!!
here is the scoop i have a 289 in my 67 mustang and it tuns rough so i got the vacuum gauge on it and it was right on 17 but it still ran rough and i had already adjusted the timing prior to smooth it out the best i could so i set the engine to TDC tonight and dropped the distributor in the appropriate location and went from there but it was stil kinda rough i was wondering if i could meet with some one nearby in PHX,AZ i live near 43rd Ave & Dunlap(Olive)
or i could come out to you but i am stumped and as a college student i need all the help i can get thx in advance
Old 11-22-2006, 04:53 PM
PerfDistIgnition's Avatar
PerfDistIgnition
PerfDistIgnition is online now
FTE Sponsor
If you decide to get a new distributor, consider our D.U.I.-Davis Unified Ignition or our custom curved Duraspark distributor. Please see them at:
http://www.performancedistributors.com/forddui.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old 11-22-2006, 06:55 PM
scottman70's Avatar
scottman70
scottman70 is offline
First thing you should do is check the spark plug wires and make sure you have each wire going to the right cylinder, if that is'nt the prob check for fouled spark plugs, check your distributor for cracks,is the rotor new? the points could be burned and worst case scenario you check each cylinder for compression and see the strate of the motor.......There is a ton of different things it could be, a mechanic could scope the motor to figure out what the prob is and then you could do the repair yourself to save some $$$$$
Old 11-22-2006, 10:18 PM
Melchiah's Avatar
Melchiah
Melchiah is offline
i replaced the dist. with a brand new DS2 dist and wiried it to an MSD 6 box and the plugs, wire, cap , and rotor are new i am reading about 17 on the vac gauge but thats as high as i can get it but i think i am gunna take it to mustang corral on northern
4tl8ford
32
08-05-2014 07:19 PM
ConcreteAce
06-15-2013 06:01 PM
4tl8ford
08-22-2012 07:58 PM
4tl8ford
20
08-12-2012 07:39 AM
460lover
Arizona Chapter
17
06-10-2002 11:17 AM
Quick Reply: I Need Help!!!!!!
