well, this is my first post, and mybe you guys could help me. I have a 390 4bbl in a 68' F-250. I love the truck but, when i'm going down the road it (without warning) will quit. no sputters or pops. the tach still reads ok so i know the coil is firing i replaced the coil, points and condenser. a few weeks ago it quit at the end of the street so i coasted it into the yard. I was dead and wouldn't fire at all. the next moring i went out to check the spark, etc. i hit the key and it started and ran beautifuly. any help, it's hard to fix a problem that's there one minute and gone the next.
This is an odd one all right. My first thought is a loose wire killing the ignition system, but you say you're still getting a reading on the tach, I assume when the engine is still turning with the momentum of the truck as it slows to a stop, but not firing. Hmm...
The very first thing I would do at this point is to get under the hood and pop off the dist. cap and check the spark right at the source. I like to pull the coil wire from the cap and wedge it somewhere so that the end is about 1/4" from a ground, then, with the points off the cam and closed, (key on) open and let them shut again a few times with my thumbnail. If all is as it should be, you should get spark at the coil wire,as well as at the points themselves. If this is done at night you can often see any shorts in the system that are going to ground as well. I'm wondering if that might be the problem right there...
I assume you've checked for fuel at these times, so you know that it's an electrical problem and not a fuel problem?
You might want to consider a Durapsark conversion as I did on my '68 F250CS (if you prefer cheap, like me!) or a change to some other form of aftermarket electronic ignition.
I tend to think it might be a fuel problem..say vapor locking or a float sticking...if the tacks working the points are..and electral problems dont normaly fix their selfs ...bill
I guessing this is why you replaced coil. points ect. And you still have the same problem.Humm well What, I would do. When it dies out. Hot wire it and see if you can get it started up again. This will by pass your key switch. If it starts you know were to look for your problems. Ford had problems with some types of the key switch pigtails. I had troubles with mind and had to replace it. To hot wire it. Run wire from hot batt.terminal to ign side of coil
hope this helps in some way..my 2cents
orich
When you say it's dead do you mean it won't even turn over or it cranks but won't start? If it's cranking I would put in a clear fuel filter to see if you have a piece of rust in your fuel tank that is blocking the fuel outlet the suction from your pump pulls it tight on your outlet then as it sits the pressure releases and allowes to start again,with the clear filter you can see if the filter is empty than watch it fill backup as the suction releases,I've seen this twice in 40 years.
it's getting plenty of fuel and by dead i mean it cranks but don't fire at all, but when it does start (no always) it don't miss a beat, I hot wired it and that seems to cure the problem so back to the parts store for the ignition swich Thanks for the help
When it dies, run out with a test light and check for juice in the obvious places.
Sometimes the insulation on the wiring under the hood on these old trucks gets hard and allows the wires to break in half. I chased a similar problem for a friend of mine and it turned out to be an ignition wire broken in half that would create an open and closed circuit at will. While it was running we started jiggling wires until it died.
I have replaced the condensor when i did the points and the coil. the primary resitense may be my problem too i had a 4bbl autolite carb with what i think was a bad float, any i back fired and caused a pretty large fire, the paint i got for the black spot on the hood blended well and some of the wires did get burned and even though they look ok from the outside i should try and replace them too although the wire checks out ok with the test light.
You might want to use a ohem meter..i have seen ingition switches..cut in and out.. but go over the wiring really well before you change it out..good luck bill
thanks for the help i should have enough work to keep me busy while it sits for the winter. Getting this fixed should renew my trust in the truck whitch is good because it's daily transportation april-october.
