Looking for Driveshaft replacement!
Here are the specs I have on it right now?
-3" dia main tube
-16 spline, 1 3/8" slip-joint shaft
-24" length from center of u-joint yoke to center of carrier bearing.
-U-joint looks to be about 3 5/8" from from the end of each endcap to the other.
Thanks!
There are several shops locally here in L.A. that specialize in this work...there's gotta be someone in your area...you might check with a big rig parts house for a reference.
Not all C-6s came with a slip yoke in the rear.
Many came with a bolt-on yoke instead, just like you find on the back of a 4 speed transmission.
Now he does have another option, but it is probably not worth it unless his current transmission needs rebuilding.
Find an FE patterned C-6 with the slip yoke rear, and have it rebuilt. Be sure to get the slip yoke out of the rear like wizzard said. Buy the whole bent up driveshaft if necessary to get it. They might even throw it in for free. You can then have a single piece driveshaft built.
By the way, a driveshaft is never lengthened, it can only be shortened. If additional length is needed, the yokes are cut out and welded into a longer new (or different) tube.
Good luck!
See my next post.
Don't restrict yourself to the early '70s trucks, like s couple of previous posts have already mentioned. The later ones have larger yokes, usually, which can be put into larger tubed driveshafts. You may be able to find a complete setup from a later truck, but which has larger U-joint yokes. If the driveshaft is bent, that is OK, the shop can use the yokes and weld them into new tubes. I did this on another truck, and it worked just fine.
If you are trying to mate a smaller yoke on the truck to a larger one in a later tube, use what is called a conversion U-joint.
A conversion joint has two different sizes along the axes. One axis has the larger size caps (and usually a longer length from cap to cap), while the other axis has a smaller set of dimensions. This is what wizzard was referring to, when he mentioned the different sizes of caps in a U-joint.
They come in a variety of dimensions, as Jeepsters, mudders and other 4x4 enthusiasts are changing out transmissions and rear ends quite frequently. These non-standard alterations mean it is easier to use a conversion joint than it is to make a driveshaft exactly fit a particular installation.
Hope this helps!
I do have a bolt-up C6 with no slip joint. I don't want to drag race it. I just want it to go down the road without giving me a massage from all the vibration. Now I like a massage as much as any other guy, but I already have a little import road race car with solid motor mounts and an uncounterbalanced 4 cylinder so I get my fill of vibration in that thing.
The reason I'm looking for other alternatives, is that the spline shaft was quoted at $130 for just the part, another $70 for the slip yoke that goes over it. Toss in U-joints and the labor and I'm right around $400. The only reason I have to do anything is because the spline shaft and slip yoke are worn out. The driveshaft is fine otherwise. It has a brand new carrier bearing. I'm going to get the U-joints changed because there is a tiny amount of play in them. Oh, and I'm having Inland Truck Parts do the work. They are the cheapest I have found around here if you want it done right.
The reason I've been having trouble finding parts in the boneyards around here is another story. I heard that several years ago, the city or some action group decided to "reclaim" an area near downtown that had a bunch of old junkyards to make some creek a nice place. Well, they bought out all of the junkyards and crushed everything. Consequently, out of the 20+ junkyards we have around here, most of them only carry vehicles as far back 1990 or so.
In the end, I found a used slip yoke for $15 and a longer used driveshaft with the right spline shaft on it for $50. So far, I'm $135 ahead of the game assuming labor and U-joints stay the same.
Anyways, I was asking because of the whole "many van parts up to 1986 fit our trucks" statement. I was hoping I could find a vehicle to ask about when looking for the driveshaft for my truck. I did find one that was exactly what I needed, but it looked like it had been sitting in the weather since 1972 as nothing was usable on it at all. I appreciate all the suggestions though. That's why I love this place!
