Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
help with cleaning iac valve
Old 12-23-2006, 11:19 AM
r1killen's Avatar
r1killen
r1killen is offline
ok so my code said misfire in bank five replaced coil pack and plug just in bank five and cleaned throttle body and replaced pcv valve,,,truck still idl'e rough the throttle body was definantl very dirtl how do i remove the iac vavle is it the one with the gasket on it on the top left intake with a plug also going in it and do i remove it and clean the inside with a carb cleaner,,,,if i do the fuel filter how do i depressurize,,,thanks
Old 12-24-2006, 03:10 PM
S.A.L.'s Avatar
S.A.L.
S.A.L. is offline
IAC has a plug, yes.
Carb cleaner works well.
Open the fuel cap to release most of the pressure.
Old 12-24-2006, 06:31 PM
r1killen's Avatar
r1killen
r1killen is offline
well
my svs light just cam back on, i did replace the spark plug and coil pack in bank five like the scanner said,,,misfiring,,,it's much better on the highway but i guess the light coming back on means there is still something wrong,,it does still idle very rough,,does the iac valve have 2 screws and a gasket on it also,,,should i clean that and replace all the plugs...
Old 12-24-2006, 06:40 PM
S.A.L.'s Avatar
S.A.L.
S.A.L. is offline
Yes; 2 screws and a gasket. It's easy to clean so go ahead and try it. What is the new code?
D REECE's Avatar
D REECE
D REECE is offline
make sure u didnt knock the injector wire off when u pulled the coil out i know i have done that before. also u can get u a long screwdriver or something to stick against the injector while it is running to see if you hear it clicking spray some of that carb cleaner around the intake while it is running see if you have a vac leak. it should have a lean code or o2 code if that is the case
hollenjoe
Modular V8 (4.6L, 5.4L)
07-28-2011 08:55 AM
nagetech
06-01-2011 09:45 PM
mlytc
1997-2006 Expedition & Navigator
03-14-2011 03:38 PM
jcstratt
1997 - 2003 F150
01-31-2006 11:28 PM
paleryder
1978 - 1996 Big Bronco
09-30-2002 12:11 PM
Quick Reply: help with cleaning iac valve
