Bed removal
Old Nov 10, 2006 | 04:03 PM
CrimeScene's Avatar
CrimeScene
Bed removal
What is all envolved in removing the bed off an 4x2 6cly 88 F-150? I looked or tryed to find it in my Haynes and did not see anything on it.
Any idea on how much it weighs?
I need to remove the fuel pump off the rear tank and I want to get a good look at the wiring to see if any needs replaced.
3 garages have tryed fixing my fuel probloms so now I am making the time to to it myself and right.
CrimeScene
Old Nov 10, 2006 | 04:07 PM
mikeyswood's Avatar
mikeyswood
Six bolts and two tail light harnesses. You could probably lift it yourself, but two guys will reduce the possibility of a whoopsie.
Mike
Old Nov 10, 2006 | 05:24 PM
frederic's Avatar
frederic
Don't forget to disconnect the fuel filler hoses from the door assemblies. Otherwise the bed ain't coming off.
I have no idea how much the bed weighs, but four average guys can lift it off if you do not have an engine crane available. Two big guys if you can balance it and the wheel wells aren't terribly rusty. You don't want to cut your fingers.
Here is how I did it, by myself, without any additional manpower. Made a simple extension for my engine crane, attached four chains to the corner bed bolts (which I removed from the frame rails), then jacked the thing right off the chassis, and drove out from under it.
The whole story, including why I did this:
http://frederic.midimonkey.com/f350-bedrepair.html
Old Nov 11, 2006 | 01:15 AM
CrimeScene's Avatar
CrimeScene
Thx,that bed looks good,just had to do my doors and replace the pass side floor pan.
CrimeScene
Old Brown Truck
Jun 16, 2015 12:07 PM
Built_Ford_Tough_757
Feb 25, 2015 06:15 PM
matrix38
Nov 10, 2014 12:17 AM
dennisb56
Oct 24, 2013 02:40 PM
roperjoe
1997 - 2003 F150
15
Apr 7, 2008 09:02 PM
