Anyone running a FI setup?
Old Nov 10, 2006 | 03:13 PM
CharlieLed's Avatar
CharlieLed
I am looking at moving/replacing the fuel tank on my 56 to the rear using John Niolan's excellent article as a guide. My dilemma is whether to modify the 22 gal 1970 Mustang tank to incorporate the hardware necessary to support a fuel injected late model engine. I am considering a late model driveline with fuel injection but I would need to modify the fuel storage/delivery system to make it work. I have a couple of late model plastic tanks that have all the plumbing, and I have seen some vendors who sell specialty tanks that have the appropriate openings and mountings for this hardware...what I haven't found is an early Mustang tank that has this capability (yes, I did speak with the folks at gastanks.com but they couldn't help me).
Has anybody ventured into this realm yet? Tried to use the "search" but it seems to be unavailable. Thanks...
Old Nov 10, 2006 | 03:45 PM
Randy Jack's Avatar
Randy Jack
Charlie -
The folks at Gastanks.com get pretty funky about their tank going into a non-stock application, so I'm not surprised they weren't much help. Liability stuff, they said.
There were no early Mustangs that were EFI, to my knowledge. However, the Mustang tank isn't the only option for a rear tank. I mounted a Bronco tank (check my gallery). Tacson and Ferguson777 mounted a Chevy van tank. The Chevy tank fits into the frame without frame modes. The Bronco tank only required moving the rear crossmember to the rear set of spring hanger holes and flipping it over.
Basically, all you have to do is find one that fits in the frame opening. It isn't a daunting mod to do. There is an article put together by Fergie that discusses the rear tank options very well, but I don't know where it is stored now. Maybe he'll be along to show you.
Old Nov 10, 2006 | 03:52 PM
CharlieLed's Avatar
CharlieLed
Thanks Randy...I looked at your gallery pics, rather ingenious way to work around the filler neck issue. Nice craftsmanship!
Old Nov 10, 2006 | 09:19 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Charlie,
I used a mid 80's Chevy Blazer tank in my 49. It fits between the frame rails nicely (I think there is a pic or two in my gallery) The tank comes in both a 24 and a 31 gallon, I ended up with a 31 gallon (it was a freebie) If you get a tank for an 1987 or later Blazer (or Van for that matter) it will be set up for fuel injection. GM went to throttle body injection in 1987.
The filler tube on the Blazer tank exits towards the right side of the truck. I routed mine between the top of the frame rail and the bottom of the bed.
So basically, you have your choice. If you are looking to keep it all Ford when you go for your fuel injection, use the Bronco tank. If you are going with GM fuel injection, go with the Chevy tank.
You might also give some thought to what guage you will be using also and try and match the fuel sending unit to it.
Good luck
Bobby
Old Nov 10, 2006 | 09:28 PM
Brian_B's Avatar
Brian_B
I had not seen the gas tank door mod you did Randy. That is really nice. It looks like it should have been there all along.
Old Nov 11, 2006 | 10:17 AM
CharlieLed's Avatar
CharlieLed
Found a guy here local that has a 31 gal 87 Blazer tank listed on Craiglist...going to check it out today. Thanks for the tip...
Old Nov 11, 2006 | 09:37 PM
bobbytnm's Avatar
bobbytnm
If I had to do it again I would try and find the 24 gallon tank. I mounted mine up even with the top of the frame and it still seems like it hangs a bit low.
If you work a deal on the tank, see if you can grab the straps, filler tube, etc
Good luck with it
Bobby
REDHTGT
24
Aug 2, 2012 12:02 AM
dads truck
Aug 16, 2007 09:52 AM
Rediranch_too
May 2, 2007 10:11 AM
fordtruckandtractor
Jan 9, 2005 04:52 PM
