Rear end noise when turning under power?
Old 11-09-2006, 01:15 PM
prohopwer's Avatar
prohopwer
prohopwer is offline
First of all hello and thanks for this site, I've had other problems resolved here without posting but can't find the answer to this one.
I have a '98 f-250 with 95,000 miles and when turning after a dead stop there is an extreme noise and vibration which feels like gears or a wheel bearing rubbing which goes away as soon as the front wheels are straightened out.
I've had it off the ground and looked in the differential and shook the wheels but i can't find the problem or any excessive play.
Any help would be greatly appreciated.
thanx
Mike
Old 11-09-2006, 01:34 PM
KingRanchMan02's Avatar
KingRanchMan02
KingRanchMan02 is offline
Welcome to FTE prohopwer.
Does your truck have a limited slip differential? If so, it is time to change the differential gear oil and to add a 4 oz. bottle of friction modifier.
Old 11-09-2006, 02:18 PM
prohopwer's Avatar
prohopwer
yes it does, I recently changed the gear oil $60, I'll try some friction modifier, thanx
Old 11-10-2006, 02:52 PM
Deebo's Avatar
Deebo
Deebo is offline
Souunds like a bad in board or out board CV joint.
Old 11-10-2006, 04:54 PM
prohopwer's Avatar
prohopwer
if the friction modifier doesn't work I'll check more into the cv joints, I only spotted u-joints under there and there is no noise when starting out in a straight line no matter how much gas I give it. I had a bad cv joint on my bronco II and the noise is very similar except I didn't have to be turning and barely moving.
thanx Deebo
Old 11-10-2006, 08:00 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is online now
you can get a 7 ounce tube of frictin modifier at Auto Zone for $5. that will fix it.
Old 11-10-2006, 09:34 PM
77SilverStreak's Avatar
77SilverStreak
77SilverStreak is offline
This is very common with the limited slip rear diffs, especially when warmed up. This is caused by the clutch packs for the limited slip being shimmed too tight and when turning the spider gears would turn very tight giving the shudder. Some guys had them fixed under warranty, but usually an oil change and friction modifier would cure it -- for a while anyway. Make sure you use a good synthetic oil, that is what Ford recommends and is in the newer trucks from factory.
Old 11-13-2006, 03:58 PM
B's FX4's Avatar
B's FX4
B's FX4 is offline
clutch packs could be shot, mine were
Old 11-13-2006, 04:13 PM
catalinagoose's Avatar
catalinagoose
catalinagoose is offline
Try the friction modifier. If that doesn't work, you'll probably need to replace your differential clutch packs
Old 11-14-2006, 06:38 AM
prohopwer's Avatar
prohopwer
I'm just waiting for the friction modifier to arrive, I bought it from a Ford dealer on the 9th on E-bay so it should be here soon.
I'll let you know what happens and thanks for all the replies.
Old 12-08-2006, 10:28 PM
mcanik's Avatar
mcanik
mcanik is offline
Same as my 7700
Just started doing the same thing a few weeks back. I was suspecting the diff clutches. any update on this?
Old 12-09-2006, 12:27 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
mcanik have you tried changing the oil and adding friction modifier?
If that doesn't fix it Snow Valley should have, and Totem usually has, clutches in stock.
Old 12-09-2006, 06:23 AM
mcanik's Avatar
mcanik
mcanik is offline
Will do Racer guy. Gimmee a few days. I will get back to ya with the results.
Old 12-09-2006, 08:35 AM
JimCaudill's Avatar
JimCaudill
JimCaudill is offline
There is/was a TSB on this and they would change the clutch packs. Naturally you have to be under warranty.... Find and read the TSB for more info.
Old 12-09-2006, 07:14 PM
grobertsaf's Avatar
grobertsaf
grobertsaf is offline
03 FX4 with the same problem
My 2003 SCrew FX4 (5.4/3:73 gears/limited slip diff) with 72700 miles on it did the same thing last week...had the shudder/vibration during shallow turns (1/2 to 1 turn of the steering wheel) at low speed and upon acceleration. After a 26 mile drive home, rear end was "howling."
Dropped it off at the dealer, they replaced the "Gear and Pinion and Diff Clutch Packs per TSB 05-23-30."
The repair was covered under my Extended Warranty so I can't tell you how much it cost to fix...they had my truck for two full days. I'm guessing $800 - $1000. Am I close?
Quick Reply: Rear end noise when turning under power?
