Will a Chev 350 SB fit a 1983 Buick 305?
it will easily fit and is almost a straight swap.
but, you mean straight bolt in? or physical size? physically the 305 and 350 are the same, straight bolt in... i just remembering my neighbors along time ago throwing 350's (actually 383) into the car, seemed no problem at all, but they had a th400 behind it, but the th350 out of the car would fit also.
Originally Posted by fellro86
Sometimes they put in unibells, which would bolt to both olds and Chevy motors. If it is the 305, not a 301 or 307, then it will be a direct swap.
3.8 retained the BOP bell... the GNX/Grand National 3.8 motors were still the BOPbell, the 2.8 had the same as 2.5, 4.3 was Chev, Caddy still used the BOP bell also, untill they were all front drive. The 4.1 Cad had BOP or Unibell... Fiance had an 84, first front drive De Ville was 85.
Buick never had a 305, true Buick other than 231(3.8) was back into the early 70's, but the Olds 307 and Pontiac 301 were used for a bit.
The 4.3 V6 used the std Chevrolet bell housing
The RWD 3.8's used BOP pattern bellhousing, The FWD 3.8's used the Metric pattern tranny
The 80's RWD Buicks were just as likely to have a 305 Chevrolet engine installed in them as a 231 Buick or a 307 olds.
GM went "corporate" with the engine lineup in 82. No more B-O-P patterned engines.
NOPE; The BOP pattern engine didn't go away untill the redegsin of the full sized cars in 1991. In fact for some strange reason from 87 to 90 the 307 OLDSMOBILE engine was the std engine for the Chevy Caprice wagon.
**My source: The Wall Street Journal, clear back then. And yes, the subject did make 6:00 news.
The switch by GM from the Olds engine was during one of the gas shortages. In addition to the price of the engine, I think the thing that really made the people is the Olds engine had a better fuel mileage rating than the Chevy. It was a class action suit and a bunch of people got money from GM for the secret switch. Ford and MOPAR never promoted their products as having different engines in different brands so they didn't have a problem.
firstrider
01-03-2017 11:01 AM
SgtSudds
01-08-2013 05:39 PM
