is my rear end still good???
'54 f100, volare ifs, future 302/c6 going to be dropped in. i'm still working on the frame/suspension. i recently purchased a ford 8" rear end from a '70 mustang. i put new brake parts, and axle bearings/seals in the rear end. i kept the rear end in the garage, and the garage caught on fire. the brake shoes are brittle, and the nice colored brake shoe spring kit looks charred. the nicely painted rear end housing is ugly now, and has more surface rust on it. how can i tell if my housing, and axles are still good? i know i'll have to re-do the brakes, springs, bearings, seals, and everything else, but i don't want to do this work, to find out that the axles or housing are junk.
thanks,
john.
thanks,
john.
I wouldn't be concerned much unless the thing was cherry red and the fire department sprayed it. I could see a problem with warpage in that case. Otherwise it should be alright. Do the axles still spin OK? I'm sure that the grease is cooked out of the bearings, but if the axles still turn without binding, it probably isn't warped.
