Just Like the Swiss...Stuck in Neutral
Hi everyone. Great forum here. Very similar to my Harley Forum.
Anyway, I have a slight problem that I could use some verification on. I have a 94 Bronco/Automatic/302. A few minutes ago, my child and I were left stuck in a parking lot because my shift lever on the column wouldn't engage a gear. It was sloppy and loose feeling and the truck acted as if it was stuck in neutral no matter what I did. Even in Park, I could roll it. It wouldn't start, obviously.
My wife eventually came and picked us up, but, before we left, I found a gold colored bolt on the floorboard/driver side. It appears to be some sort of Torx-like bolt and is about 1.5 to 2 inches long. Do you think this fell out of my column linkage or something and is prohibiting my shift lever from engaging? I'll troubleshoot tomorrow when I don't have to watch the baby, but, it would be nice to have a plan of attack.
The truck has been a beautifully running vehicle prior to this incident.
Any help would be appreciated and thanks in advance.
Spliffy
Spliffy
I'm assuming that you broke the actuator. It is a cast part that breaks all the time. (not the actuator rod) You can get someone you trust to sit in the drivers seat and hold the brake. Crawl under the truck (nice if it's lifted) and pull off the linkage on the tranny and shift it by hand to drive. Than at least you can drive it home.
