2000 V8 5.4 Ford F-150 Firing order.
Sudden misfire of cylinders 5678 on 4.6
Need some guidance. A elderly couple need me to try and fix their 2000 Ford Expedition with the 4.6 V8. The elderly gentleman changed the thermostat hoping to fix a no hot air from heater. This did not fix the no heat problem but the next time they drove the vehicle it had low engine power. They had it checked at autozone with a scanner and it sets misfire codes for cylinders 5,6,7, and 8. Could this be a coincidence that all 4 went bad at the same time or is there a fuse, harness or what that may be causing this problem.
jim1234
13
02-18-2020 12:34 PM
Scotty150custom
13
03-30-2016 01:20 PM
smoovmusic
03-24-2016 10:26 AM
