Need To Know: Romeo And Windsor-physical Difference
Can Anyone Out There Tell Me How To Tell The Difference In A 4.6 Romeo, And A 4.6 Windsor. Just Say That U Didnt Have The Truck To Get A Vin, No Sticker On The Valve Cover, How Would U Tell The Difference. I Work At A Salvage Yard And We Shipped A Motor In And My Cust. Is Convinced That We Got Him The Wrong One, Anyone???
This should be pretty easy:
The Windsor is a 5.0 or 5.8 liter engine, no 4.6 windsor to my knowledge. It is a pushrod overhead valve V-8. They can be found in 1996 and prior F-150s, and 1997 and prior F-250/F350. The 4.6 Romeo is an overhead cam v-8, which came in the new body style F-150's in 1997, and the new F250/350 in 1998. The easiest physical difference is the spark plug location. In the windsor the plugs are on the lower side of the valve covers, right between the exhaust manifold runners. You can physically see the spark plug hex. On the Romeo 4.6, they are on top, next to the fuel injectors. The romeo uses long spark plug boots, and the plugs are completely concealed with the boots in place. Also, the Romeo has plastic valve covers with a rounded protrusion at the front to cover the overhead cam sprockets. And the alternator sits right on top center of the motor, the late windsors have them on the passenger side. These engines are totally different, there is zero interchangeability.
The following 2 users liked this post by BowTieHatr:
Outside of calibration issues with the ECM, the only way that 4.6 Romeo wouldn't swap for a 4.6 Windsor is the 6 vs 8 bolts at the flywheel. How many bolts does the valve cover have? 11 or 14. Car designated Romeos have 11. All Windsors (and I'll have to check this) and the truck Romeos should have 14.
-Kerry
-Kerry
I have a Romeo 4.6L in a '97 F-150 and it DOES NOT have plastic valve covers, and unlike other 4.6L versions, it also has an aluminum intake manifold instead of plastic.
Actually This entire answer is incorrect. They do make a 4.6L Windsor AND a 4.6L Romeo. The Windsor uses an 8 bolt crankshaft and flywheel, where the Romeo uses a standard 6 bolt configuration. Also the cross-supports for the Main caps is different.
it had plastic valve covers from the factory
and all the NPI motors had aluminum intake manifolds
- they use the same camshafts
- same exhaust and intake manifold bolt patterns / gaskets
- different valve/cam covers
-different head to timing cover bolts
tomsolie
Modular V8 (4.6L, 5.4L)
56
03-29-2024 11:35 AM
