Bull Bar Questions 04' F250
Jason how you get away with that on the LIE with no front plate? that's why I went with the full size. Lights sit higher and the bar is in front a bit so your light have some protection. Mine is from smittybilt this type: http://www.cabelas.com/cabelas/en/te...133&hasJS=true
and the fogs won't need to be touched.
Originally Posted by Netfly
Jason how you get away with that on the LIE with no front plate? that's why I went with the full size. Lights sit higher and the bar is in front a bit so your light have some protection. Mine is from smittybilt this type: www.cabelas.com/cabelas/en/templates/product/standard-item.jsp?_DARGS=/cabelas/en/common/catalog/item-link.jsp_A&_DAV=MainCatcat21412-cat20133&id=0036436521931a&navCount=4&podId=003643 6&parentId=cat20133&masterpathid=&navAction=push&c atalogCode=IG&rid=&parentType=index&indexId=cat201 33&hasJS=true
knock on wood no one has said anything yet!
so don't jinx it!!
BFD here . . .
Glad it works for you.
Here in Texas they would really like to write you up. Just recently passed a law that you can't even have a cover on your plates (frt or bk), clear or otherwise.
Not worth the look for leaving the frt plate off. So I have the plate relocsation bracket on mine.
Originally Posted by Lonewolftx
Tell me, how did you get that pic in the post?
manage/create
edit
go to your pic and click forum codes-for displaying image in forum posts
new window opens
full size image-- copy http://--------------------.jpg
go to post
post reply
select insert image
new window opens
paste address
There is probably one button that does all of this and I hope somebody tells me what it is.
#29
F 250 6 liter
1999 to 2016 Super Duty
03-24-2011 11:27 AM
