excessive steering pump pressure???
Old Oct 28, 2006 | 08:20 PM
dieselmissos's Avatar
dieselmissos
Unhappy excessive steering pump pressure???
We have a 1994.5 F450 7.3DI (powerstroke) with 165,000 on it. Recently had to change the power steering pump because we couldn't find the fluid leak. Old pump blew its cap off a couple of times, finally the cap hit the manifold and melted! Now we are wondering if the leak was from under the cap. The new pump (OEM) ran 500 mi and blew the (new) cap off. This seems to only happen when the truck has been run at highway speed for an hour or more. This power steering system goes to the brake booster, then on to power steering box. There is a return line from steering box, and also a return line from the brake booster. Anyone have any ideas why the pressure would fluctuate enough to be blowing the cap off? Is there any way to test the steering box to see if its causing the problem? The truck steers fine when the system's working right. Brakes are OK also.
Old Oct 29, 2006 | 12:09 AM
79f-250custom's Avatar
79f-250custom
Maybe your overfilling it? and run a better PSF that can handle extrem heats.
just my .02
Mitch
bghnkinf250
55
Nov 12, 2017 11:33 PM
bghnkinf250
'80-'86 HOWTO's
61
Apr 21, 2015 10:07 PM
clarkbre
Apr 16, 2015 10:12 AM
gramicko
Oct 24, 2013 10:29 AM
89ford73
Jan 21, 2005 10:07 AM
