No start !
Old Oct 26, 2006 | 08:46 PM
94E150's Avatar
94E150
No start !
This morrning my '94 E150,5.8 would not start.
I have had van for a year and it has run perfect.
Had to go to work,so I did not have time to look at it.
The one thing I did notice is that when I turned the key
to the run position I did not hear the sound that I allway thougth
to be the fuel pump? Forgot to say the engine turned over at
a normal speed.
Thanks for any help. Carson
Old Oct 26, 2006 | 10:30 PM
wickymustang's Avatar
wickymustang
Have you checked that the pump did run? I would look at the fuel pressure regulator to see if it is leaking and making it an extended crank situation. Also, if you can get a pressure reading to see if you are at the specified pressure for your year and model.
Old Oct 27, 2006 | 10:41 PM
vanwho's Avatar
vanwho
Just another thought to add. Take a look at the fuel pump reset switch. If it has tripped, push the button in and try to start it again. Had a 87 Mustang that did that a lot. Replaced the switch after numerous times it left me stranded. No more problems. Dealership never found out why. Mechanic took a wild guess and it worked. Just my 2 FWIW
Old Oct 28, 2006 | 09:40 AM
94E150's Avatar
94E150
Thanks for help! But need more!
Does anyone know the closes place to aplly 12v to run in tank fuel pump? '94 E150,5.8 v8,35 gal. tank.
Carson
CCope94
Feb 16, 2015 01:16 PM
musclecars90
Jan 16, 2014 07:56 PM
submariner638
Oct 15, 2012 07:14 PM
Kentwa
42
Apr 9, 2011 07:27 PM
pchristman
Jan 6, 2004 10:55 AM
