IS this a bad thing to be broken?
IS this a bad thing to be broken on my leaf?
just wondering this thing broke on one of my leaf springs.how worried should i be about it?and should i have it fixed or is it ok like this?
The leaf spring on the left is the one with the broken clip thing.
the one on the right has a good clip thing see theres one on each side 2 of them.sorry i dont know what there called.
is it ok the drive my truck with this broke?
The only issue you'll run into with that "clip" missing is that the leaf springs in the middle of the pack may start to twist and come out of alignment with the other springs in the pack. It's really of no safety concern unless you end up with a leaf contacting a tire. I've seen people use stainless hose clamps in place of the 'clips' but I think it looks tacky. Is there another clip on the other end of the spring pack? If so, drive it and forget about it.
Cody
Cody
ok thanks i didnt know what those things were called.if they sell them at a parts store ill just order a new one.not sure how i would get it put though there is some sort of big rivit holding those spring clams in.and no there is only one on each spring these are stock leaf spring for my stock 250 not my lifted truck.thanks for the help
If you do a lot of off road stuff, the leafs will end up spreading out. I guess under a load this could break a leaf in the pack, though I have never seen it happen. I have been thinking about using muffler clamps on mine. The real question is how to remove the rivet and replace it that holds the clip in place.
yeah thats what i wana know how do you get that big rivit out?????????? i guess yours is broke to.
go to jeffs bronco graveyard www.broncograveyard.com and get one. they are really cheap. i know we cant talk money and prices on this site, so lets just say around a couple gallons of gas would be a good swap for one.
