injector and cosmetic question?
Ok i just got my dp-tuner installed last week and I love it. So I talked to jody and asked him what my next best upgrade would be and he said AC injectors? What are AC injectors?. And my second question is my dad has an 02 dually that a stroker. And he busted the instrument panel glass out the other day. Does anyone know where you can replace that plexi glass at??? Thanks alot
Ill just tell you guys what Im up to. I was gonna trade my truck off but after driving a few 6.0's and hearing the horror stories I gave up on that. So I'm sticking with the old 7.3 but I wanna get more power out of her. So I just installed the dp tuner and I've already got the 4" exhaust, 6637 intake and gauges and everything so now I wanna do injectors and turbo. Im wanting to get as much power out of this truck as I can safely. I dont wanna shuck a rod. But I would like to get a little more than stage ones atleast but I dunno if I can do that safely. Thanks
Like Chase said, look into hybrids and have Jody tune them for your PMRs. Any way you go with injectors, you will have to have your chip re-burned to run them. Since your looking into injectors, you might also look at fuel system upgrades like a regulated return and the in-tank mods.
swamps - Swamp's Diesel Performance
DI (may have them) - DI Performance - Your Powerstroke, Duramax, Cummins Performance Headquarters
Probably some others, Swamps seems to be the most talked about hybrids from what I can tell.
Ron (Rons Power Stroke) has got his from here and is more than happy with them
Full Force Diesel
Full Force Diesel
Full Force Diesel
Full Force Diesel
Jerid- if you want to put forged rods in your motor you will have to have the crank balanced. I would leave it alone unless you are dying to pull the motor and break it down.
Ron's are Stage 2's with 100% over nozzles though. Cass does make a killer set of hybrids though- most of the builders call their hybrids stage 3's.
