how can this be?
Old Oct 23, 2006 | 06:34 PM
bradplock's Avatar
bradplock
how can this be?
hey guys, help me out here. i have a 96 bronco 351W. i've had it for about 6 years now and i'm just now getting around to learning about gears. first things first. my axle code is 19 so open diff right? well, where i work, we park on gravel. when i spin out in the gravel i get 2 equal tracks in the gravel. is this possible with an open diff?
Old Oct 24, 2006 | 04:31 PM
bradplock's Avatar
bradplock
Unhappy
anyone....
Old Oct 24, 2006 | 04:43 PM
smokinwater420's Avatar
smokinwater420
I have a 1994 Bronco with same engine. 8.8 rear end and a dana 44 up front. My rear had a LSD from factory and open front. As far as I know not much changed from 94 to 96. I run 33's with a locker in back and 4.10 gears now and it's great!
Old Oct 24, 2006 | 04:44 PM
andym's Avatar
andym
Code 19 means you have 3.55 gears, open carrier. Just because it didn't come with it from the factory doesn't mean a previous owner didn't put one in. If you jack up one rear wheel, put the tranny in neutral, can you spin that wheel? If not, it's got some kind of traction aid device in it.
Old Oct 24, 2006 | 05:08 PM
bradplock's Avatar
bradplock
Cool
okay well one wheel up and it spins, this sucks...
Old Oct 24, 2006 | 11:24 PM
85e150's Avatar
85e150
Yes it is possible to spin both with an open diff.
Have you gotten stuck because of it yet?
Old Oct 25, 2006 | 01:57 PM
75F350's Avatar
75F350
Cuz you are on gravel, the tires have little or no resistance, so both can throw rocks like a pro. Any resistance on one side or the other would eliminate both tires spinning at the same rate. This is why we call em "one wheelers".
