Acceleration Problem
Old Oct 23, 2006 | 12:16 PM
angle_finder's Avatar
angle_finder
Cool Acceleration Problem
I have a 2004 6.0 FX4 F250 SD Crew Cab Short Bed Turbo Diesel. Lately when I am accelerating the engine will hitch as if the engine is not getting fuel, or the turbo intermittently quits. Has anyone experienced this?
Old Oct 23, 2006 | 12:34 PM
tvsjr's Avatar
tvsjr
Not very definitive...
Mileage? Preventative maintenance performed? Mileage since last fuel filter change? Recall/problem history? More details...
Old Oct 23, 2006 | 01:10 PM
angle_finder
The fuel filter was changed 10k miles ago; the truck has 45k on it. I have the truck checked on a regular basis (I use it for work). In fact, I just had it in for a checkup and an oil change. I have had no problems with the truck prior to this. This issue had just started.
Old Oct 23, 2006 | 03:46 PM
ryaneverk2's Avatar
ryaneverk2
Thread moved to 6.0L PSD section.
Old Oct 23, 2006 | 05:18 PM
BowTieHatr's Avatar
BowTieHatr
could be egr valve opening when it shouldnt be. you experiancing any smoke?
Old Oct 24, 2006 | 01:02 PM
angle_finder
No, I have'nt noticed any smoke, but I will check it out.
Old Oct 24, 2006 | 01:27 PM
BowTieHatr's Avatar
BowTieHatr
also pull your map sensor hose of the intake and make sure it is not stopped up.
Old Oct 24, 2006 | 01:30 PM
2006PSDSD's Avatar
2006PSDSD
Does this happen all the time, or just when it's cold? Could be injectors, my friend has gone through about 3 sets on his '04 with 75k.
Old Oct 24, 2006 | 04:51 PM
angle_finder
No, it does it when it's warmed up. It happens intermittently (Rare but annoying).
I'll try the map sensor, thanks.
Shocker05
Mar 25, 2025 01:36 PM
quaders4ever97
Paint & Bodywork
Nov 3, 2006 03:25 PM
wsu0702
Nov 1, 2006 06:13 AM
ricknolan
Oct 21, 2006 07:21 PM
