Need Spray Bedliner Advice - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-22-2006, 07:22 PM
SNEAKY F350
SNEAKY F350 is offline
SNEAKY F350 is starting off with a positive reputation.
2007 F350 King Ranch PSD Crew Cab FX4 Long Box True Blue/Beige
I had the Xtreme sprayliner on my other trucks but the local accessory shop no longer does them. My X-treme was supposedly just like Line-X and worked good for me. I have never seen the Rhino other than on TV but am open to it. Which is better, Line-X or Rhino?
Old 10-22-2006, 07:29 PM
scooter80
scooter80 is offline
scooter80 is starting off with a positive reputation.
Rhino is thicker (1/4") than Line-X and tends to be a bit softer, but stays nicer looking if you don't gouge or otherwise harm it. It tends to keep it's gloss, in otherwords.
Line-X is the way to go if you really use the bed.
Old 10-22-2006, 07:39 PM
fishnatic
fishnatic is offline
fishnatic is starting off with a positive reputation.
Hi, Just had my 06 f150 harley done with linex looks great, a friend told me after i had it done there is residential grade and commercial. i believe i ended up w/residential. my 2 brothers both work at the dealership where i bought, they endorse line-x
Old 10-22-2006, 08:25 PM
Deluxe05's Avatar
Deluxe05
Deluxe05 is offline
Deluxe05 has a great reputation on FTE.Deluxe05 has a great reputation on FTE.Deluxe05 has a great reputation on FTE.Deluxe05 has a great reputation on FTE.
Line-X. Hands down. I've had it on three previous vehicles, and it will eventually find its way onto my current Super Duty.
The only "failure" of the liner that I know of first hand was in a friend's truck (carpenter, by trade). The company honored the lifetime warranty without a question. And, to my knowledge, he continued to haul around all of his tools & equipment in that truck for 11 or 12 years without any other problems with the liner.
On the little known side...several branches of the military have authorized & been using Line-X for bomb/exposion blast mitigation lining in buildings & vehicles, for salt water protection on subs & ships, and a varity of other uses. That says a lot, in my opinion.
Old 10-22-2006, 09:27 PM
Lonewolftx
Lonewolftx is offline
Lonewolftx is gaining momentum as a positive member of FTE.Lonewolftx is gaining momentum as a positive member of FTE.
Arrow
I had an Xteme don't here in Houston, Westside. If you want to use them I can give you the contact info, they do the spray in work for Machaik. PM me if you are interested.
Old 10-23-2006, 11:52 AM
F250tuff's Avatar
F250tuff
F250tuff is offline
F250tuff is starting off with a positive reputation.
I have read in other posts that if you have a Line-X liner and it gets damaged, any Line-X shop will honor the warranty and make the repair.
If you have a Rhino liner, you must use the shop who installed it, to make the repair. If the shop is out of business, you are out of warranty.
Old 10-23-2006, 12:13 PM
jonsk
jonsk is offline
jonsk is starting off with a positive reputation.
I dont believe that is true. LineX warrenty is honored in all states.
If your dealer goes out of buisness they will honor your warrenty at another dealer. Here is a link, follow the nationwide link on this page, and it tells you such.
http://www2.line-x.com/ns/warranty.html
Old 10-23-2006, 12:18 PM
F250Wheels
F250Wheels is offline
F250Wheels is starting off with a positive reputation.
I have rhino, it's softer and things seem to stay in place better and not slide around, but I do have A few goughes in it, I think the line-x wouldn't have gotten damaged as easy.
Old 10-23-2006, 12:21 PM
Lonewolftx
Arrow
[QUOTE=jonsk]I dont believe that is true. LineX warrenty is honored in all states.
http://www2.line-x.com/ns/warranty.html[/QUOTE]
I think you misread the F250tuff post as he was saying this as well . . .
It was the other liner he felt would be an issue.
Old 10-23-2006, 12:37 PM
F250tuff's Avatar
F250tuff
F250tuff is offline
[QUOTE=Lonewolftx]
Exactly
Old 10-23-2006, 12:55 PM
PERFORMANCE RED
PERFORMANCE RED is offline
PERFORMANCE RED is starting off with a positive reputation.
I only have experience with Line-X. I have slid some pretty heavy stuff over it and it is some dang tough stuff. So far i see one little mark on the bed floor but it didn't cut all the way thru the liner to the bed.
I would diffently get Line-X again.
Old 10-23-2006, 01:48 PM
Autobahn F-250 Lariat's Avatar
Autobahn F-250 Lariat is offline
Autobahn F-250 Lariat is starting off with a positive reputation.
Thumbs up
I love my LINE-X wouldn't have any other way you can ask them to spray it on a little thicker... they sprayed the front where my tool box sits a little thicker... $345 out the door w/ military discount
Old 10-23-2006, 03:52 PM
jonsk
jonsk is offline
You guys are right. I misread the post. My bad.
Old 10-23-2006, 05:21 PM
Ray diesel
Ray diesel is offline
Ray diesel is starting off with a positive reputation.
Thumbs up
LINE-X, only experience, but very satisfied with it.
'07 F250 PSD shortbed
Old 10-23-2006, 06:17 PM
07diesel4X4
07diesel4X4 is offline
07diesel4X4 is starting off with a positive reputation.
I have to say I am sold on Rhino liners. It is much thicker and seems to absorb shocks much better than my cousins Line-X liner. Rhino liner feels much stickier also, and sure keeps things from slipping around. Just got rid of my 2000 Ram and the bed still looks like the day I had it sprayed. Garden hose usually is all it takes, maybe a little car wash soap and a scrub brush on a broom stick. Just had my 07 sprayed, $420.00 out the door, as a comparison for any one interested.
Later.
g
stephentheman
04-30-2016 11:45 AM
CrewChieF350
50
05-25-2010 12:15 PM
mikedeason
04-13-2007 11:50 AM
mikedeason
15
03-08-2006 04:53 PM
fatman66
New York Chapter
05-26-2004 05:00 PM
Quick Reply: Need Spray Bedliner Advice
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
