wiring turn signals
Old 10-21-2006, 11:55 AM
engr368's Avatar
engr368
engr368 is offline
Question wiring turn signals
I have a 1950 ford F1 that I'm restoring and the turn signals have me stumped on how to wire just can't figure it out .It has a positive ground system 12 volt can any one tell me .
Old 10-21-2006, 09:11 PM
Beast12's Avatar
Beast12
Beast12 is offline
Thread moved to 1948-1960 truck forum. You should get more help here.
-Matt
Old 10-21-2006, 09:45 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
Received 3,769 Likes on 1,817 Posts
I think that all of the turn signals were aftermarket in those years. Here are a couple of wiring schematics for the 48-52 and the 53-56 years.
https://www.ford-trucks.com/user_gal...=94430&width=1
https://www.ford-trucks.com/user_gal...120434&width=1
Are your turn signals the type that clamp onto the steering column? I'll poke around a bit and see if I can dig up a wiring diagram. Hopefully someoen here as some insights into it.
Bobby
Old 10-22-2006, 06:08 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
The first thing I would do is convert the electrical system to negative ground and then work with the turn signals. With a positive ground system it only a matter of time before you fry something...it's sorta like being right handed but having to do everything left handed...
Old 10-22-2006, 10:02 AM
engr368's Avatar
engr368
engr368 is offline
I received the truck as a gift and the starter and generator was converted to 12 volt positive ground all ready.The turn signals clamp on the side of the steering wheel all I need to know is how to wire it in to the stop lights.
Old 10-22-2006, 10:19 AM
engr368's Avatar
engr368
engr368 is offline
yes they clamp on
Old 10-22-2006, 01:48 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Received 2,051 Likes on 802 Posts
Here is the wiring diagram from SignalStat. You have to have the switch with seven wires to use them with your stop lights. If you have the switch with five wires you will have to run separate lights for your brakes.
I have kept my trucks negative ground and have never run into a problem. I just make sure if I have to jump start a truck I don't allow the two vehicles to touch. I am also keeping my trucks stock and not adding any accessaries except for the turn signals and stock radio.
Skm0807
Electrical Systems/Wiring
04-22-2017 08:13 PM
stowbilly96
1999 to 2016 Super Duty
04-11-2017 05:10 PM
Cbad285
01-13-2016 03:03 PM
forddriver78
08-26-2015 08:03 PM
51FordTN
12-15-2012 05:57 AM
Quick Reply: wiring turn signals
