IP, Smoke, Time, Power - Snap-On MT480
Bigrestruckmi and Dave S.,
I think your right about the 4-68J ROO and 4-68X ROO. I remember running across a reference to IP’s regarding low and high altitudes and the fuel curves for each.
Also Bigrestruckmi, what did you use to test the cetane of the fuel – brand and range if you have it? I think I may have found one on line, talk about a needle in a haystack, for $60.00. API gravity range between 29 and 51.
And finally do you check the timing on the diesels, if so what do you use the luminosity or pulse style?
Thanks, 93
Thanks, 93
Originally Posted by Dave7.3
So would you highly recommend making these timing adjustments? I am a little fraid of blowing up my truck knowing my luck lately...Did you notice alot more power after the timing adjustment?
As far as recommending a setting I’ll say this: Either buy a meter (either the luminosity style or the pulse type) or find someone that has one. Then I would start out at either 2* ATDC @ 2000 rpm using the luminosity probe or 8* BTDC @ 2000 rpm using the pulse adapter. Take it for a test drive and then make adjustments as needed. Again my van is a 1993 with the 7.3 NA IDI.
<OCetane hydrometer: I’m going to get one. I’m going to take a sample out of my fuel tank for a sample that way I can measure the additive effects as well. It will probably be a few weeks before I do this but once I do I’ll give you an update.
<O93
Ok this is what I’ve got. I’ve just been doing the country errands; 3 days cold starts (not plugged in, overnight temps around 30F) warmed up until engine was at least in the low-normal range. Took the boat over to storage about 8 miles away, few trips to the auto store, fleet-farm, and wal-mark. All told a little over 155 miles, took 8.5 gallons of fuel = 18.235 mile per gallon.
I’m really happy with that especially with the short trips, the power seems better also. But I’ve done a little rechecking this evening trying to figure out the first set of timing numbers I got (18* ATDC @ 2000 rpm, and 10* ATDC @ 625 rpm) before I moved anything, and why when I got closer to TDC they seemed to catch each other? Well I checked the timing a few times and what I found was that the timing is moving around between about one degree at 2000 rpm (between 2* and 3* ATDC), and between 3* and 4* BTDC @ 650 rpm. As I increased the rpm from 625 to 2000 this is what I saw, pretty much as soon as I got above idle the needle came to or almost TDC. About 1200 it was a little over .5* ATDC, and by 1400 it was about 1* ATDC, 1800 was about 1.5* ATDC, and 2000 was about 2* ATDC. All of these numbers were plus or minus a percentage of a degree. I think the black smoke I was getting at low rpm’s before I bumped the timing from .5*/1* ATDC to 2*ATDC @ 2000 rpm (pumps now about 1/8” to the left of the original timing mark) was just the timing being below .5* ATDC or possibly BTDC during low rpm acceleration.
I have questions that I’d like to get some opinions on –
Question 1. I’m thinking the IP is just plain worn out. While moving the IP timing does seem to help, the engine really does feel like it has more power and I believe I’ll get at least a little better fuel mileage. I’m wondering what it would be like with a new IP and possibly injectors also?
Question 2. On an engine with a new IP and injectors does the timing follow from 650 to 2000 rpm? Or does it advance at a faster rate as the rpm’s increase. Certainly I would expect it to retard as it’s doing now? Is there some type of a curve?
Question 3. The cold advance seems to work, it advances about 1 or 2 degrees when hot-wired. Moving the mechanical advance lever while running at any rpm changed nothing. The lever / plunger seem to move ok but do nothing to change the timing offset. I’ve been using additives for about 14 months (got her in July 2005). Is there hope for freeing up mechanical advance or is it time to replace the injector pump?
93
93
on
if someone comes along sometime with experience,or has heard of a worn ip causing erratic timing id like to know as well.this will help me determine when the ip needs to be changed if this is the case i suppose?
answering these questions above will be appreciated.
93_E_350's Last Activity: 12-02-2006 ......bummer.id like to hear more long term test results.
