Sponsored by: Real Truck
tire clearance
Old Oct 19, 2006 | 11:06 PM
nwstumpy's Avatar
nwstumpy
tire clearance
Having trouble with NO tire clearance on my 96' 250. There is virtually 1/4 inch clearance between front tires and bumper, while in a turn. Getting ready to get new tires and with more tire tread I forsee a problem.
Any suggestions : cut back bumper, lift kit ( have camper so do not want to get too high )?????
help meeeeeeeeeee
nwstumpy
Old Oct 19, 2006 | 11:51 PM
bf250's Avatar
bf250
cut the bumper!
i cut mine on my 1995 f350 to clear my 35"x14.5" tires, all i had was a leveling kit but still wanted more clearance for off roading.
its the cheapest and best way, what size tires?
and i really think the bumper looks better cut back anyways. i can provide pics if you need them (i think i have a pic of the cut!)
Old Oct 22, 2006 | 02:26 PM
bluesea112's Avatar
bluesea112
bf250, I would like to see a pic if it is not too much trouble. This is the first time I have heard of cutting the bumper, and I am very interested in seeing how you did it.
Old Oct 22, 2006 | 04:01 PM
nwstumpy's Avatar
nwstumpy
No made the cut and came out sweet. Plasma cutters work nice and neat. And was having clearance problems with 285, stock calls out 235's, nothing tall just a bit wider.
nwstumpy
Old Oct 22, 2006 | 04:41 PM
ReAX's Avatar
ReAX
Your truck is 10 years old, springs have probibly settled. Moog may have a stock replacement that you can pickup cheap, you should be able to clear 31's with little effort.
Old Oct 22, 2006 | 05:40 PM
wolfe1104's Avatar
wolfe1104
On my 95 i had the same problem. Instead of cutting the bumper I just took 2 or 3 rectangular cut pieces of 5/8th steel with two holes drilled in them and stacked them
between the bumper mounts and bumper. I cant remember if I used new bolts or not but its pretty simple to tell if you need them. It didnt look bad either, the gap on top was a little bigger but not noticable.
Old Oct 22, 2006 | 06:00 PM
Lou Braun's Avatar
Lou Braun
As a couple of other folk mentioned, go ahead and trim the bumper. You cut the lower rear edge of the bumper so that a small triangle of metal is removed.
Put a piece of duct tape over the part of the bumper that needs to be cut, mark the cut line and cut it with a sawsall. File any rough edges when you are done, then put a coat of black rust-proof paint on the cut edge.
I did this on my '95 4WD F250. It took about a half hour and allowed running 12.5-33's with no rub.
Lou Braun
