tranny-fluid
Old Oct 19, 2006 | 03:11 PM
factory594x4's Avatar
factory594x4
Question tranny-fluid
I topped off my 91' ranger 4-speed manual+overdrive with the propper fluid to the propper level. Now it is spraying fluid everywhere. It seems to be coming from the output shaft seal. I don't know???? Is this common??????
Old Oct 19, 2006 | 03:17 PM
Joelski's Avatar
Joelski
Proper level should be 1/2" below the fill hole, otherwise it will leak from the seal or vent tube. This seems to be a common mistake that corrects itself on reaching the correct level. Hopefully this holds true for ya.
