2 different oil dipstick locations on 351m?
I just picked up a 79 f150 with a 351M from an impound lot. The engine seems to run great, and I need to replace my 400 in my truck. I planned on just doing a straight swap, but I noticed that the oil dipstick on the 351 is located in the front of the engine on the left, and on my 400 and my dads 351m the dipstick is on the left. There was even a owners manual with the donor truck, and it shows the dipstick in the front. Problem is there is no dipstick in the tube. Can I use my old dipstick from my 400, or do I need to track down a new one?
hmm, thats right. The donor truck is a 2x4, mine is a 4x4. I didn't think that made any difference with the engine. Will I be able swap the engine from the donor straight into mine, or will I need to take the oil pan off my 400 and put it on the 351M? Other than that, are there any differences that I need to be aware of?
I need a running truck yesterday and I don't have the money to build the 400 the way I want to, so my plan is to pull the 351, put in a new timing set and waterpump and main seal while I have it out, and then stuff it in my truck. Then I'm going to rebuild the 400 the right way, and when I finish (it will probably be a while) then I'll swap it back into my truck. I don't want to do the minimum to get the 400 going, I want to redo the whole thing right.
One question though, since I have to swap out the oil pans, should I replace the oil pump? And how hard is it to replace the main bearings while I have the pan off? I'm just thinking that if I have everything apart why not head off any problems.
If you put a rear sump oil pan on a motor that had a front sump oil pan, you have to swap the oil pick tube & screen as well. Also there is a special bolt on the 3rd main bearing cap, that has to be swapped also. This bolt supports the rear sump pickup tube.
If the new motor has good oil pressure, I wouldn't fool around with the oil pump or bearings, if it is only a temporary swap.
Originally Posted by kilog55
hmm i have 2 dipsticks on my motor one on the drivers side middle of the headers, and one on pass. side front of motor behind alt. why is this? it has a swapped 4-speed stick in it. was an auto from the factory
The dipstick behind the alt. is for a front sump oil pan. You should not have this dipstick. You should not have a front sump oil pan.
You should not have both dipsticks. One of them will not work correctly, if at all.
