Surging, high RPM idle, 'miss'...???
Hey all,
Great forums.
'04 6.0l Excursion with ~48K. This morning it was surging, mostly under acceleration. I waited to see if it'd go away once it warmed up, but it persisted. Whipped it into Ford dealer and while they were opening up the bay the Excursion 'lurched' and RPMs increased 200-300RPM and stayed there. Pulled into the bay and it started to 'miss' in idle or park...I'll describe it as 'diesling'.
It did something similar last week, but went away after fuel and restarting. Tank was above half today.
Luckily, it did it at the dealership and they'll check it out. I ordered up and oil and fuel filter change, but what else could I be looking at?
It might be a couple days b/c I'm was unscheduled, but I'll post back the serv. dept. response.
Thanks.
Great forums.
Thanks.
Update:
Service dept. just called and will have the vehicle overnite again. They want to do some testing when the vehicle is cold. Apparently, they are investigating something with 3 of the cylinders. Should know more tomorrow.
Luckily it's all covered under the 5yr/100k warranty minus $100 ded.
Ugh...that doesn't leave me with a lot of confidence. What causes this?
I did have a report done by my local dealership before I bought this out of town vehicle. The seller also gave me service records he had. There were a couple things regarding fuel/water separator and EGR, but nothing to do with injuectors.
Thanks for all the replies.
Originally Posted by vloney
be prepared for injectors 3,5,7, and 4 to follow shortly. Have you ever had an oasis performed to see any previous work?
Your prediction may be coming true. Today on the way into work (35 mile drive...80% highway) I started to experience an 'issue'. Coasting up the exit ramp and then getting back on gas to maintain speed it felt like it started to surge again. The same lead in scenario that lead to the almost stalling out. To try to illicit a 'feeling' it kind of felt like the transmission/engine were trying to determine what gear to be in...you know that lag you can get in between?
I knew the ramp wasn't where I wanted to be stranded so I figured I'd kick it the pants a bit. It accelerated, but when I had to slow to make a turn and get back under gentle power I started to notice it again. I was w/i a mile of work, so I kicked her again and made it to work no problem and it idled good for a few minutes until I shut it down.
The very first time this happened I just shut it down and restarted it a couple of minutes later. It ran fine for about 1 week until it acted up and I took it in. Does this sound logical?
Also, since getting it back it doesn't seem to have the power boost it used to and the gas mileage has dropped off.
Any insight is always appreciated.
What Ford did ~ 2 weeks ago.
Replaced fuel filters
Replaced injectors 1, 2, 6, & 8
Power balance test
I had oil changed too.
Thanks!
If it helps at all, here's what the service report said for the October fix.
Quoting (word for word, letter for letter):
48188 CK for engine surges inspect and verified concern. Performed performance diagnostics 1-10. Fuel pressure is OK. DTC for cylinder #2 ballance, performed power ballance test cylinder's 1, 2, 6, 8 missing. R&R injectors 2, 6, 8 (left bank). R&R injector #1 (Right bank) reassembled. Road test-OK. Reperformed power balance-OK. Reperformed KOEO- Pass. Reperformed KOER-Pass.
Vehicle build date April end, 2004...a Monday vehicle.
I contacted the dealer about my event on 11.8.06 and they basically told be to keep driving the vehicle until I have a certifiable event to confirm against.
Today after driving into work I let the vehicle idle in neutral while I gathered my things. The RPM's kept rising/falling thru a ~200RPM range, which is uncommon.
I'm now keeping an 'event log' that will hopefully help the tech.
Well I scheduled an apt. with the SD for Wednesday. Another reoccurance of the fluctuating RPM at idle (also happened 11.10.06) accompanied with a low 'who-ing' noise (hard to describe). In addition, I got a lurch while backing up my driveway. After that I sat and watched it idle and then the RPMs jumped real quick about 300 and came back down, but the engine sounded different after that...kind of louder, like on a colder start-up. This is all happening after a +30min. drive home from work. No AC compressor on.
Hopefully we'll find the culprit because my confidence in this vehicle is fading rapidly.
