Sponsored by: Real Truck
Newbie Tech Info Needed
Old Oct 9, 2006 | 05:11 PM
SC_Hooch's Avatar
SC_Hooch
4th Gear
I have a '03 F350 DRW. Even when I haven't used 4WD in a while I still will flip it on to lube everything up front. Three years and I haven't had any issues with it. Untill 2 weekends ago. I went to Pismo Beach and as soon as I put it in 4WD the front end started to whine. Take it out of 4WD and no whine, so I only used it after getting stuck in 2WD.
This is where the Newbie info is needed. What would cause this whine? I filled my diff when I got home not knowing if that would even do anything, and it still whined when in 4WD. It's comming from the front for sure because I had my lady drive it slow in 4WD and I walked along the side and listened. Its comming from the outer part of the axle around the hub/tire. I had her shift it on the fly to 2WD and as soon as the drive line stoped spinning the whine was gone. What the hell? Please help. Thanks
Old Oct 10, 2006 | 06:21 PM
SC_Hooch's Avatar
SC_Hooch
4th Gear
Old Oct 10, 2006 | 08:04 PM
bneafus's Avatar
bneafus
Sorry Buddy, Not a mechanic,but maybe wheel bearings? I'm sure one of the smart guys will pipe in soon...
Old Oct 10, 2006 | 10:05 PM
SC_Hooch's Avatar
SC_Hooch
4th Gear
Yeah I hope so. I really dont want to take it to the dealer. I dont think it's the wheel bearings though, it dosen't whine when in 2WD.
Old Oct 15, 2006 | 12:13 AM
SC_Hooch's Avatar
SC_Hooch
4th Gear
Old Oct 15, 2006 | 12:20 AM
ReAX's Avatar
ReAX
Best case, your front end was low on fluid or the fluid was contaminated. Bad side would be ujoints, front axles seals or bearings. When you were walking next to it should not have been going fast enough for ring and pinion whine unless it was very far out.
Fill it up, and check the axle seals for leaks. If you have the ability, jack the front end up and spin the wheels by hand in 2 and 4wd. This may give you a better sence of where the noise is coming from or there is debris causing it.
Old Oct 15, 2006 | 12:46 AM
EnviroCon's Avatar
EnviroCon
Since you're saying that it's only happening in 4x and you don't think it's the wheel bearings, there's really only 2 other things I can think of that would make a whining noise. The R/P gears ReAX mentioned or the pinion bearings. Both of these are only in operation when the hubs are locked and/or the front driveshaft is spinning. Generally, if it's the gears, the whine will change with the speed of the driveshaft and may come and go. If it's the pinion bearings, then it will happen at any speed and not stop until the vehicle stops.
Do what ReAX recommended and spin the front by hand just to make sure it's not the wheel bearings.
Old Oct 15, 2006 | 11:02 PM
75F350's Avatar
75F350
If you manually lock the hubs, does it continue to make this noise? Lock the hubs without engaging the transfre case. The wheel bearings are not your problem. The bearings spin always, regardless of wether the truck is in 2wd or 4wd.
You also mentioned that you filled the diff. Does this mean that it was empty? Where did the fluid go? Why did it require filling.
Really sound like a carrier bearing or a pinion bearing that went dry.
Old Oct 16, 2006 | 10:06 AM
SC_Hooch's Avatar
SC_Hooch
4th Gear
Sorry, I didn't have to "fill" the diff. I ment I checked it. I opened it up and 3 pumps of gear oil latter it was comming out the fill plug. So I'm guessing the fluid level was fine. I haven't tried locking the hub's with out the Tcase engaged, so I'll try that this afternoon and see whats up. Thanks.
