International Region Australia
72 aussie f truck
Old 09-23-2004, 01:27 AM
donracing69's Avatar
donracing69
donracing69 is offline
Exclamation 72 aussie f truck
Help. I have a 72 cab that I want to fit to a 78 chassis. I need some info on wiring the "sports style" dash (mainly the ammeter). I am also after some parts, so if anyone knows where in Australia I can find some bits, please let me know.
Old 09-30-2004, 05:59 AM
BigF350's Avatar
BigF350
BigF350 is offline
G'day to a fellow Aussie...
Where do you live?
There are some good places in Queensland if you live anywhere near there, or there are couple of wreckers in Melbourne I know of...
Check out the yellow pages
Old 09-30-2004, 06:29 AM
donracing69
Hi,
I live in Tassie and we have only one F truck wrecker and he has very little and charges like a wounded bull.
Old 09-30-2004, 05:48 PM
BigF350's Avatar
BigF350
BigF350 is offline
Well your best bet would be a Melbourne wreckers.
Bit unfortunate that you live in Tassie, where in Tassie?
I used to live near Burnie...
Old 12-20-2005, 08:12 AM
effie351's Avatar
effie351
effie351 is offline
G'day donracing69,
Where did you find your "sports style" dash?
I was thinking of building a new instrument cluster with aftermarket gauges as I havn't been able to find a factory full instrument dash to suit my '79.
Would rather buy a cluster than build one as I have several other projects on the go.
Mike
Old 04-04-2006, 07:58 AM
OzFTrucker's Avatar
OzFTrucker
OzFTrucker is offline
Sorry to reply to a pretty well dead post but the full instrument dash froma TC or TD Cortina slots straight into the 75-79 dash, just need to recalibrate the tacho for the V8(if you have one) and run the appropriate wires and change the senders to suit, did the whole conversion for $120 into a 78 F100 but it was a six so didn't need the tacho recal, this would cost $50 or so from aninstrument specialist.
Old 09-18-2006, 06:35 PM
pickups's Avatar
pickups
pickups is offline
If anyone needs any parts I have them. I'm located in Melbourne and will post them across Australia. Parts are to suit f100-f350 from 1973-1979. Good doors , bonnets, XLT trim , lights , dash inserts and clusters etc. I'm not a wrecker I'm an enthusias. Call 0401 570 341 or (03) 9337 8778
Old 11-06-2006, 05:12 AM
revhead64's Avatar
revhead64
revhead64 is offline
Thumbs up
G'day you blokes.
Yep....I agree. The Cortina TD type tacho gauge cluster is a bolt in deal. The Tacho function has a "trim pot" so all you have to do is turn it one way or the other to calibrate it against a known good tacho. Simple as that.
The only problem I found with the Cortina Gauge cluster is some of the warning lights don't match the original F100-350 cluster. Also you need to run an extra wire for the tacho. Don't forget to use the Cortina type Oil Pressure sensor as the regular Ford F series type didn't work in our '75 F100.
Cheers.........Barry.
72 f250 camper special 2wd
25
06-04-2014 03:44 PM
72F100CarolinaBlue
10-11-2009 06:35 PM
72 high boy
1966 - 1977 Early Broncos
01-03-2007 03:11 PM
rodbender
01-26-2005 07:40 PM
bigred72
Exhaust Systems
10-23-2002 07:07 PM
Quick Reply: 72 aussie f truck
