Problem with 2000-F150 PATS system.
Hi all. I have a 2000 F-150 4X4 with 56000 miles. The problem I’m having is with the PATS system. Sometimes when I try to start the truck the PATS system will not recognize the key or something of that nature. So far I have been able to turn the key off and on a few times or unhook the battery cable, reconnect and the truck will start. Hopefully some one can help. 1st, Can I bypass the system? 2nd, Is there any way to reprogram without involving the dealer? 3rd, what other options do I have? I really like the truck and would like to get it repaired. Thanks in advance for the help!! Ed.
Sorry. I have tried two out of the three keys I have for the truck. Daughter has the other one and I should get it tomorrow. You can tell when you turn the switch on if the truck is going to start or not. If the theft light is blinking rapidly and the odometer shows dashes not numbers when it won't start. Yesterday I tried my key early in the day, no start, wife’s key an hour later, no start. My key again around lunch, worked fine. My key again around 3:00pm no start. Wife’s key around 8:00 last night, no start. Should have put this in the first post, fustrated and in a hurry. Thanks for the help! Ed.
I have a 2003 F-150 4x4 with 63,000 miles. I have the same problem, sometimes it starts and sometimes it doesn't. Tried different keys, even bought a new key thinking the chip in the key was bad. My dealer looked at it, did not know what it was. They think my after market auto start has something to do with it. Could be, but I had this auto start in the truck for 2 years (never had starting problems) then took it out when I was selling my truck. I decided to keep the truck and re-installed the auto- start and this is when the problems began. Any other thoughts would be much appreciated.
Originally Posted by Black03Screw
Thanks for the tip Kawasaki. I know that my bypass is under the dash, so it must be something else. Dave, thanks for your lead and I will adjust my steering wheel lower to see if that will help.
Good Luck and let us know.
There are three things here.
1. The digital speedo goes out suggests it's a dash problem or power as it's seperate from PATS.
2. If you turn the ignition on and the lamp flashes for failure, wait a couple minutes and it might flash a two digit code that will suggest what the problem involves.
3. You can do a self test of the dash micro-processor driven system that may give some more info on the problem. You need the HEC codes and info to interpet the test steps.
An fyi; The Pats communicates with the PCM so you can't get around this unless it is programmed out, in the PCM. The info is contained in the PCM software VID block. If that info is corrupted, a cel lamp and code 1639 will be the result.
My truck started doing the exact same thing this week. Theft light flashing rapidly, odometer dashes instead of numbers, turns over but won't start. I disconnected the battery cable and the reconnected it and the truck started right up. My truck is a 99 F-150 -107,500 miles - 4.6 - 5 speed - 4x4. NO aftermarket electronics installed. NO alarm system, no tilt steering, and no auto start system. Any ideas?
Thanks,
Scott
Thanks,
Scott
Last edited by bigredmachine; 10-12-2006 at 04:22 PM. Reason: forgot to give some info
Big Red you and I have almost the same truck, only difference is mine has the 4.2. I am going to check all the grounds tomorrow and will let you know what I find out. Mine will also start a couple of times after unhooking the bat cable, but it's not a permanent fix. This is hard to do at times. Have you ever blocked the boat ramp on tourney day??!! :-)
