1991 Ford F150 not starting - Ford Truck Enthusiasts Forums
Old 10-07-2006, 01:35 AM
milkbone
milkbone is offline
milkbone is starting off with a positive reputation.
I have a 1991 Ford F150 automatic with a 302 v8 with electronic ignition. My brother was driving the truck and the starter turned on intermittently while the engine was running. Then the truck stopped running and could not restart it. The starter did not even click or turn on. It was completely dead. Power is in the cab and can hear the fuel pump power on. Basically you turn the key and nothing happens.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I have checked the internal fuses, replaced the starter, solenoid, ignition switch, ignition control mod, and neutral/safety switch. Still nothing at the key. I do not know what I should replace or try next.
By the way when jumping the posts at the solenoid, it does crank the starter. It appears something may be draining the battery slightly.
Looking for help.<o></o>
Old 10-07-2006, 07:02 AM
headcustodian
headcustodian is offline
headcustodian is starting off with a positive reputation.
Check your battery cables. clean battery posts. make sure neg. cable has a good clean ground. Sounds like a ground problem.
Old 10-07-2006, 07:41 AM
todd31277's Avatar
todd31277
todd31277 is offline
todd31277 is starting off with a positive reputation.
sounds more like a short for the starter to turn over for no reason. might be the ign switch itself. or you might try holding the swith to the start position and shake the wires under the dash. tapping on the switch too. the elect. switch not the key and tumblers.
digitaldemon
01-28-2013 04:19 PM
fly4fun35
16
02-20-2008 11:17 AM
millaman
1997-2006 Expedition & Navigator
09-16-2007 11:01 AM
jd111404
04-21-2007 01:25 PM
Doogie S
2004 - 2008 F150
01-31-2007 02:36 PM
Quick Reply: 1991 Ford F150 not starting
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
