95 f150 Hard to Start
Originally Posted by mikemustang289
No, the tanks don't fill off each other, but my forward tank has a bad fuel pump so it isn't used. I only use the rear tank. How hard is it to remove the tank and install a new pump? does the bed have to come off?
No but most say it is a lot easier to take the bed off than to try and drop a tank.
Originally Posted by hutch1973
I have the exact same issue with my truck. We've had a few cooler mornings the last week or so and it's acting the same way. Usually it'll pop off in a second or two, but like he said, at least ten seconds. The minute it fires up it runs fine, no sputtering or hesitation. If you fix yours before I fix mine, pass on the solution..lol. I plan on checking codes in the a.m.
I first noticed it when the temp dropped below 45 at night, and last night it got down to 38, definately worse. Need to fix it before winter hits, it's a long walk to work.
If you want check to see if the check valves are bad, put a fuel pressure gauge on the fuel manifold, turn on the key, ground pin #6 of the test (DLC) connector.
At this point the gauge should read 45 psi for an 8 and 55 psi for a 6 with the engine not running.
Un-ground pin#6 while looking at the gauge and see how long it holds pressure.
It should hold for a moment and then drop very slowly, if it drops fast you have a bad check valve.
Test connector (DLC) (wire colors are wrong):
http://i54.photobucket.com/albums/g9...taLinkConn.jpg
jfid
1999 to 2016 Super Duty
12-05-2013 05:38 AM
Wingwalker
21
12-31-2012 08:17 AM
fjones
06-21-2001 05:18 PM
